Remote starters..Ford vs other
With the DEI setup
Uses a new remote
does NOT engage the factory alarm/horn noise
my interior lights stay on when I lock the truck till they go off on their own
my interior lights do NOT come on when unlocking the truck
I would rather have my stock remote plain and simple. my questions are
what are all the specs on the Ford unit? does it use my stock remote? do the parking lights come on when you start the truck?
With the DEI setup
Uses a new remote
Uses a new Ford factory remote that replaces your original one - has the extra button to start it and all the other normal keys to lock/unlock your doors, etc.
Interior lights stay on when you lock the truck and they turn on when you unlock the truck with it - same as original remote.
Parking lights come on when you start the truck.
Locks all the doors when you engage it. It acts like the key is in the engine if you engage it while truck running and pull out the key when you stop somewhere so you have to either a) push the lock down manually - power door locks won't stay locked, or b) lock it from the keypad on the outside of the door - this is what I do.
Here's the problem with the Ford remote starter. Because of the interface with the GEM module, the radio will stay on when the command start times out (after running fifteen minutes). This is more getting into the habit of always turning off the radio when you stop somewhere. I caught this the first day I had the new Ford remote and I called them about it - no solution to it and doesn't sound like they have any correction planned for it. Now I always turn my radio off when I get out - summer or winter. I use it to cool down the truck in the summer and heat it up in the winter. Sometimes I start it if am somewhere I can't plug it in during the day and just let it run for fifteen minutes mid-day so it will start.
Right now, we are at -34 C and -45 C with the wind chill. (In Farenheit, that is -29F and -49F with the wind chill). Remote start comes in handy, but I still need to plug it in if it sits for more than six hours in this weather.
The range on the Ford unit is limited if you are not in line of sight, but for the most part that is not a problem for me. It produces a short beep when you press and hold start button to let you know that it has received the signal - also lights come on if you can see your truck. If it can't start it and times out (doesn't turn it over very many times) then it will give you three short beeps to let you know. I find in weather like this if it isn't plugged in and sits it will time out upon trying to start it and I will just go out and put the key in to start it to save the battery. Always fires with about one or two extra cranks that the remote doesn't produce.
Not much else I can give you without having the manual in front of me - pretty basic unit with not a lot of extra options like the aftermarket models but it works fine for my purposes.
I thought my interior lights went OFF when i locked it..maybe Im wrong..been a while?
John, yes you can have just a RS on your truck. If you don't have an automatic trans, the selection is more limited.
OP, at least on alarm systems (I am not sure about RS only), there are outputs to give you courtesy lights, Supervisory lights, factory alarm enable/disable. The installer probably wired the dome light for a slight delay after locking. As far as the remotes go, there are a lot of nice 2way fobs out now. If you must have a plain jane, then you can use any aftermarket, but take a look at the fancy ones, they don't add all that much to the cost.
the only thing my remote start is tied into is the ignition and the parking lights. the dome lights go off as they would when yo ujust close your door and dont lock the truck...like 30 or 45 sec or whatever.
not worried about cost...but why buy a whole alarm when I have one in the truck for free?
And you don't have an alarm system
You have lock confirmation. This is often confused with a factory alarm system.
Not sure how to interface with the GEM to turn off the light when you arm the truck.
It is up to you how much protection you want. However, no one pays attention to alarms, let alone just a horn honking. A siren with an odd output that you are familiar with will help you discern if it's your alarm or another. The intrusion on the stock only gives you your doors, with a little sensitivity adjustment, the impact sensor can tell if your tailgate is dropped or slammed. Another plus is the extra visual deterrent, a single led flashing should suffice, but the more light the less your vehicle will appear as an easy target.
Does your RS do door locks? The door lock should be a neg pulse. You should be able to tap that pulse into the arm/disarm wires in the kick panel. You can easly wire it to work with the stock if it locks the doors.
and negative on the vibration sensors. Im at the racetrack all year and have to listen to all of the *********s that have that. that thing would have to be turned so far up it would be useless.
the RS is now also my door lock function too. but thats all it does is door locks.
I didn't see the info I wanted, but since your RS does lock, if it's wired in the VSM. When you lock it, the VSM sees the command as coming from a door lock. Perhaps someone with a better diagram could see a way to wire it to the VSM so it believes the factory remote sent the ground pulse.
