worried
Old Dec 13, 2008 | 08:34 PM
sheaff44's Avatar
sheaff44
worried
2004 f150 5.4 4wd 36000 miles.Everthing on the truck works fine,but once in a while it will sound like i am draging the muffler while starting out.Trans. works fine during this noise.no check engine lites or any thing else. Pulled codes and Ford dealer found nothing(motor & Trans)This one is realy driving me nuts.Hope someone will have an idea. Thanks
Old Dec 13, 2008 | 09:33 PM
98greensi's Avatar
98greensi
apparently the emergency brake is bad on these trucks (04-05) and cause problems, hanging up etc rather the cable sizes up or the liner on the brake shoes comes apart
Old Dec 14, 2008 | 09:26 AM
sheaff44's Avatar
sheaff44
Will find out today,just going out the door to check on your advice.If this is it i will be very thankfull.10.25 AM in Pa. I will get back to you
Old Dec 15, 2008 | 04:26 PM
sheaff44's Avatar
sheaff44
worried
Checked out brakes as posted,not the problem.Had the same noise today and put the truck in park,noise was the same execpt it had a whinning noise with it this time.First time in the morning is not my best time,so i got back into truck and drove it ,,,,hard.Well the noise stoped and everything works fine.
No check engine lights or any sign of anything being wrong.Works fine,just once in a while it makes like its draging the muffler.
Old Dec 15, 2008 | 08:12 PM
xjcamaro89's Avatar
xjcamaro89
So it makes the rattle noise even when your in park and not moving? If that is the case maybe there is a loose heat sheild or something like that is just reverberating with the vibration of the truck somewhere and isnt anything mechanical. Just a thought.
Old Dec 15, 2008 | 08:36 PM
efx4's Avatar
efx4
Yeah. Mabey a heat shield (or shields) that surround the cats are rattling. Go underneath the truck with a hammer and lightly tap the cats and areas of the exhaust system and listen for rattles.
Old Dec 23, 2008 | 09:05 PM
sheaff44's Avatar
sheaff44
I want to thank all of you for your time on this problem,as luck would have it i found that my little moter that puts 4/wheel drive in or out was hung up half way between in or out.Some lite tapping with a hammer worked.Also was told to use 4/wheel more often so as to keep it working.Again THANKYOU
