yes the wheel well is moved back.its still an 8 foot box,but the wheel base is 140 inch,from 133 inch (thats based on a regular cab pick up truck of coarse) so the over all lenght of the truck is the same as a regular cab long box.
yes the wheel well is moved back. its still an 8 foot box, but the wheel base is 140 inch, from 133 inch (thats based on a regular cab pick up truck of coarse)
so the over all length of the truck is the same as a regular cab long box.
Since the S/CS wheelbase of 140" is 7" longer than a 133" wheelbased truck, the overall length will not be the same.
They are the same length truck. I thought I was scoring something rare when I bought the upper racetrack trim from a junkyard. I took it home, added it to the stash of other trim, it was the same length as a regular 8' bed.
It's still a standard cab with an 8' bed- The axle is all that is moved. Different bed to allow for the axle being further back, same overall dimensions as a standard longbed pickup.
