Guitar Hero Question
Old Dec 13, 2008 | 06:14 PM
Duffman1990's Avatar
Duffman1990
Question Guitar Hero Question
I picked up the new guitar hero a little while back and was wondering if anyone knows how to use both guitars, a mic, and drums all at the same time on the PS2? It has 2 controller ports, and 2 usb ports...I tried using a multitap but it didn't work. With the mic plugged into usb you have to have a controller plugged into a controller port, or so it seems.
Old Dec 17, 2008 | 11:42 PM
rednekrailroader's Avatar
rednekrailroader
The Xbox version has a USB 4-place hub that plugs in so you can run everything off of the same USB slot. Can't speak for the PS2 though (mine's a 3).
Old Dec 21, 2008 | 07:28 PM
Duffman1990
Kind of a drag...thanks anyway
Old Dec 21, 2008 | 11:51 PM
jimbo beam's Avatar
jimbo beam
I've used Guitar hero, and rock band, on a PS2 using the same setup rednekrailroader spoke of with the 4 slot usb hub. I have the PS3 versions with all the instruments, and a buddy has the PS2 version minus the instruments. We've successfully used my instruments from the PS3 version on his PS2. I believe the USB instruments are the same for all versions PS2, PS3, and X-box 360. I've played all three and they seem the same to me.
I'm not sure but you may need to mess with your USB settings in one of the systems menus. Perhaps its something simple like your USB support has been shut off or something.
To make them work on his PS2 we have the drums, mic, and wireless guitar plugged into the usb hub, and the hub is plugged into the first port on the PS2. There's a standard controller plugged into the first controller port and another wireless guitar plugged into the second controller port.
Does either your mic or drums work if you plug them into a usb port individually?
By the way you were correct, you need a standard controller plugged into port 1 when you use the microphone.
Old Dec 24, 2008 | 10:33 AM
Duffman1990
the drums and mic both work in usb ports but my problem is with the standard controller...it is keeping me from being able to use 2 guitars at once...i only have the ps2 controller port wireless guitars
Rusty_S
Dec 4, 2010 06:37 AM
fred_79f250
Jun 3, 2008 06:49 PM
ashshade
24
Feb 8, 2008 12:38 PM
rhw
Jan 13, 2008 12:32 PM
Mil1ion
19
Jun 27, 2007 12:23 PM
