2006 suddenly wont start
Old Dec 13, 2008 | 04:36 PM
HzrInAz's Avatar
HzrInAz
A couple days ago, my check engine light came on, then went off and didnt come back on. This morning, the truck cranks over, will fire very briefly but wont start. I changed the fuel filters, and put on a new glow plug module I had, and still no change. Ive been trying all day. Theres no white smoke except for when it briefly fires. What else could this be? Thanks
Old Dec 13, 2008 | 04:59 PM
dcaddi2's Avatar
dcaddi2
Pull DTC-s. Even the check engine went away, you should have the code stored.... It will help to get closer...
Old Dec 13, 2008 | 05:02 PM
Rob.D's Avatar
Rob.D
I would think an 06 would be under warranty? Take it to the dealer and let them handle it. My .02
Old Dec 13, 2008 | 05:09 PM
dcaddi2's Avatar
dcaddi2
Good point there...
Old Dec 13, 2008 | 05:18 PM
6LPSD's Avatar
6LPSD
take it to a good dealer, if you have a code reader like scantron from actron plug it into the dash ecm hookup thing see if it will spit out any codes for you, could be anything but this is a starting point.
Old Dec 13, 2008 | 05:33 PM
bismic's Avatar
bismic
<TABLE style="WIDTH: 317pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=422 border=0 x:str><COLGROUP><COL style="WIDTH: 317pt; mso-width-source: userset; mso-width-alt: 15433" width=422><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 317pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=422 height=17>Hard Start-No Start Diagnostics:</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Hard Start/No Start Diagnostic Procedures</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>1. Visual Engine/Chassis Inspection</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>2. Check Engine Oil Level</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>3. Intake/Exhaust Restriction</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>4. Sufficient Clean Fuel</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>5. Fuel System Delivery</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>6. Electric Fuel Pump Inlet Restriction</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>7. Carry Out The Key On Engine Off (KOEO) On-Demand Self-Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>8. Retrieve Continuous DTCs</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>9. KOEO Injector Electrical Self-Test (Click Test)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10a. Check VPWR During Cranking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10b and 10c. Check FICM Power During Cranking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10d. Check the RPM Signal While Cranking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10e. and 10f. Monitor the ICP While Cranking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10g. Check Fuel Pulse Width While Cranking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10h. Check FICM Synchronization While Cranking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>11. Glow Plug System Operation</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>12. Combustion Gas In The Fuel Rail Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Performance Diagnostic Procedures</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>1. Visual Engine/Chassis Inspection</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>2. Sufficient Clean Fuel</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>3. Check Engine Oil Level</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>4. Carry Out The Key On Engine Off (KOEO) On-Demand Self-Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>5. Retrieve Continuous DTCs</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>6a. KOEO Injector Electrical Self-Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>6b. Power Balance Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>7. Intake Restriction</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>8. Exhaust Gas Recirculation (EGR) System Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>9. Exhaust Restriction</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10a. Fuel System Delivery</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10b. Electric Fuel Pump Inlet Restriction</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>10c. Fuel Aeration Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>11. Carry Out The Key On Engine Running (KOER) On-Demand Self-Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>12a. Low Idle Stability (ICP Pressure)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>12b. Injection Pressure Regulator Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>13. Turbo Boost Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>14. Crankcase Pressure Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>15. Oil Aeration Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>16. Combustion Gas In The Fuel Rail Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Diagnostic Trouble Code (DTC) Descriptions</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Injector Interrupt for Enhanced Diagnostics</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Diagnose Rough Idle Only</TD></TR></TBODY></TABLE>
Old Dec 13, 2008 | 05:35 PM
HzrInAz's Avatar
HzrInAz
I will do that Monday, I was hoping there might be a way to get it going for the weekend. I already removed my banks tuner, as they always blame it for everything when I have gone in before. Unfortunately I dont have a way of pulling the codes myself.
loganmick
May 28, 2015 11:53 PM
f250rangerexplorer
Jul 17, 2014 07:59 PM
dirtcowboy
Modular V10 (6.8l)
13
Mar 21, 2014 02:36 PM
bigelkhunter
Dec 5, 2013 05:34 AM
Lacy's Her Name
Nov 10, 2012 03:13 PM
