4wd confusion
Old Dec 13, 2008 | 12:46 PM
buckeyes8603's Avatar
buckeyes8603
4wd confusion
i have a 1995 ford explorer with 160k miles and when i hit my switch for the 4wd the 4whi and 4wl blink and i read all the forum on this problem but now the 4wd light stays on but the 4wd is not engaged help
Old Dec 13, 2008 | 05:43 PM
aquanaut20's Avatar
aquanaut20
1st question,
Do you have auto or manual hubs??
Old Dec 14, 2008 | 09:37 AM
buckeyes8603
autolocking hubs
Old Dec 14, 2008 | 11:58 AM
aquanaut20's Avatar
aquanaut20
With the 4x indicator showing lite, the T/C is engaged.
If no power to front wheels first check auto hubs. Clean/flush ALL the grease out of them, lightly coat with LIGHT grease and a tablespoon of ATF.
Never pack auto hubs as they will fail every time.
Old Jan 13, 2009 | 04:10 PM
Jspafford's Avatar
Jspafford
Dude! The 1995 model explorer is the first year to use the PVH hub setup. They are not anything close to the mechanical hubs used until 1997 on Rangers!
The hubs on a 1995 explorer are operated by a blast of air to lock and unlock them. Chances are they need the o-rings replaced. There is also a trick to permantly lock them (like the 2001+ rangers) or there is now a manual hubs available... Search AVM in google for a link.
