high rpm start
Old Jan 11, 2009 | 09:43 AM
clowe's Avatar
clowe
high rpm start
I have noticed in the mornings when I first start my ST it shoots up to a high rpm (around 2800-3000). That cant be good for the engine (4.0). Anyone have any ideas?
Old Jan 11, 2009 | 12:44 PM
mediaman67's Avatar
mediaman67
dirty MAP, or air cleaner plugged up, or some other reason for the intake to be starved for air... 2500 rpms can be normal at first start up, if it's really cold out - as it would be a run rich condition, but if it doesn't settle down in a couple of minutes or so, and runs like that for a while, my guess is an air intake problem somewhere...
Old Jan 12, 2009 | 02:48 PM
marragtop's Avatar
marragtop
You should also check the PCV valve.
Old Jan 13, 2009 | 05:31 PM
Graygeorge's Avatar
Graygeorge
Intake o-rings could be leaking. Do a search and you will find some others with that problem.
andysam
Apr 29, 2014 08:21 PM
pukey
Jan 5, 2011 11:21 PM
jklapp86
Jun 23, 2008 10:06 AM
Jake719
Oct 5, 2005 08:15 AM
