4wd confusion
i have a 1995 ford explorer with 160k miles and when i hit my switch for the 4wd the 4whi and 4wl blink and i read all the forum on this problem but now the 4wd light stays on but the 4wd is not engaged help
1st question,
Do you have auto or manual hubs?? |
autolocking hubs
With the 4x indicator showing lite, the T/C is engaged.
If no power to front wheels first check auto hubs. Clean/flush ALL the grease out of them, lightly coat with LIGHT grease and a tablespoon of ATF. Never pack auto hubs as they will fail every time. |
Originally Posted by aquanaut20
(Post 6882760)
If no power to front wheels first check auto hubs. Clean/flush ALL the grease out of them, lightly coat with LIGHT grease and a tablespoon of ATF. Never pack auto hubs as they will fail every time. The hubs on a 1995 explorer are operated by a blast of air to lock and unlock them. Chances are they need the o-rings replaced. There is also a trick to permantly lock them (like the 2001+ rangers) or there is now a manual hubs available... Search AVM in google for a link. |
