ok so in the 89 i have the rear sliding glass and it rattles....alot and its driving me crazy
is there a way to tightn this down?
its mostly the npn sliding one behind the driver...thanks for any ideas
the sliding part does not rattle....
is there a way to check if it is that piece?
the solid piece behind my head on teh drivers side is the one that rattles and shakes?
thanks i will look into that
Sorry, I did not understand npn.
In that case I would look at either the interior plastic trim being loose, or the window gasket itself.
But first you have to figure out exactly what it is that's rattling.
Right now I have a screw missing from the interior trim that causes an annoying rattle.
ok i will check that out when i go outside...its like 15 deg here so im not in a huge hurry lol
if i push on the glass it stops so it could be that or the trim
thanks
