Knocking Sound/ Injectors?
Old Dec 14, 2008 | 12:03 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Originally Posted by Bigfwt04
On the Early 99 the site says that it needs to be clearanced from the turbo. How is this accomplished?
The boos fitting goes in without clearancing. The clearancing is for the fitting that goes on the boss. I used a 1/4" air grinder with the conical grinding stone. I removed the plenum bolt close to where the fitting goes so I wouldn't accidently grind on it.
Old Dec 15, 2008 | 04:59 PM
redfire42's Avatar
redfire42
Robin, you have a picture for everything? Thats awsome... If I need help with anything to where I need a picture I am asking you..
Old Dec 16, 2008 | 03:33 PM
aklim's Avatar
aklim
Originally Posted by Smokin'
it has something to do with the timing of the motor
Don't think so. Nothing changed in mine except the DI regulated return install last summer. After the air got burped it became a lot quieter. This has a lot to do with fuel starvation of the #8 injector. Ford Band Aided it with the Long Lead injector. You have 7 AD injectors and 1 AE. In my case, because I have the RR, it didn't have that cackle when I installed the AC Stage II Injectors.
Old Dec 16, 2008 | 03:44 PM
Bigfwt04's Avatar
Bigfwt04
To elevate the need for grinding couldn't you use a 90* Elbow fitting?
Old Dec 16, 2008 | 03:56 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Early 99s come with 8 AB code injectors unless the #8 was changed to an AE LL after a customer complaint. An AB in the #8 makes the "cackle" a bit louder. The CCK and a Walbro GSL 392 fuel pump has all but eliminated my cackle. It's just discernible when cold. Other PSD owners ask me why I don't have an injector knock.
Old Dec 17, 2008 | 09:47 AM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
The fitting that goes on the boss already has a 90° fitting. There just wasn't enough room to thread it on the boss.
Old Dec 17, 2008 | 10:52 AM
Bigfwt04's Avatar
Bigfwt04
Cool, Just curious, thanks for replying
walkaree
Aug 9, 2013 06:30 PM
Firefighter 1406
20
Nov 29, 2011 10:16 AM
dburress
Jan 29, 2011 09:15 PM
CWOODNHD92
23
Mar 15, 2010 11:23 PM
lifted_01_SD
22
Jun 25, 2006 07:11 AM
