Sponsored by: Real Truck
Viper Remote Start Settings
Old Dec 12, 2008 | 01:45 PM
ldg397's Avatar
ldg397
I am having a Viper 5901 alarm/remote start installed on my '06 F250 lariat tomorrow. Just wondering about which settings will be best.
First of all I live in dallas so I don't deal with real cold temps but it does get below freezing for a week or two. I also hunt in missouri and amarillo so it will see the teens and single digit cold from time to time but not on a prolonged or consistant basis. My question is at what temperature should I have the truck start up and run, for how long and how often should it do this?
I think I am going to have the alarm set to silent or "beat down mode". Other question is I see where my truck may not be able to connect to wait to start light, if so what is the best delay to use before start. I would like to set it once for all the conditions I would see but I could see where a 10 second delay would get pretty old when 95% of the weather I am in is above 80 degrees.
Last question is how long should it continue to run to cool down the turbos most of my driving is highway at about 70 to 80 mph.
Any other suggestions on settings I haven't mentioned are also welcome.
Thanks
Old Dec 12, 2008 | 03:01 PM
patrickke's Avatar
patrickke
if your having a car stereo shop install it they should know about how long to set the glow plug timer....I usually let my truck idle for around 5-7 minutes after highway driving
Old Dec 12, 2008 | 03:39 PM
Beerstalker's Avatar
Beerstalker
I believe I have my glow plug delay timer set to 30 seconds.
I don't use the automatic turbo timer as most of the time I don't need to leave the truck cool off. My EGTs drop below 400 by the time I get parked. When I am on a long trip and want to let it cool off I just hit the remote start button before I turn the key off and take it out. I'll let it run for a little while and then hit the remote start button again to kill the engine after I think it has cooled off enough.
I wouldn't bother setting it up to start and run at a certain temp either. A deisel engine takes a long time to get up to temp, especially if it's just idling, so you would have to let it run for a long time just to warm it up. Doesn't really make sense, and you'd probably just end up with wet stacking and oil dilution problems. Just start it up 15 minutes before you leave and that will get it warmed up enough to start driving it. Just take it easy for the first few miles till it gets totally warmed up.
Old Dec 14, 2008 | 10:18 AM
riggz's Avatar
riggz
I have my start delay set at 15 seconds. If you think it's a nuisance to wait this long, then you really don't need to use the remote start. My turbo timer is set at 1 minute as this is plenty long enough to get it down to under 400*. However with synthetic oil it isn't really needed.
Old Dec 14, 2008 | 11:31 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
My Viper is set for 30 second delay, run time is set for 15 minutes (default on my 5701 is 12 mins.) The auto start is every three hours and I use that sometimes if it is getting real cold with snow and ice to help keep the windows clear during the night so I don't have to spend alot of time clearing the windows before leaving early.
I, like Beerstalker, am usually cooled down by the time parked, if not I use his method or just sit in the truck for another minute.
Lee Lichterman
Electrical Systems/Wiring
Sep 13, 2022 04:41 AM
bobv60
May 19, 2019 05:33 PM
Firefighter 1406
Dec 10, 2016 12:01 AM
AndeyHall
Nov 22, 2010 09:14 PM
bigredkacy
Nov 9, 2010 08:21 AM
