superchip/10K
Old Dec 12, 2008 | 06:10 AM
kupiec20's Avatar
kupiec20
superchip/10K
i have the superchip already, will the 10K mod make any difference?
Old Dec 12, 2008 | 09:30 AM
Gobstopper909's Avatar
Gobstopper909
with my stage 1 injectors, i seen a big difference when i added a 14.7k mod to my truck with the superchip. you will def see more smoke and power. how much will depend on if you have the sticks already. be on the look out for a rougher idle. dont worry its fine.
Old Dec 12, 2008 | 09:36 AM
Talyn's Avatar
Talyn
From everything I've read on here. If you buy a burned chip, you shouldn't have to do the resistor mod. But to each his own. can always fine tune. =)
Old Dec 12, 2008 | 09:42 AM
93f1505.0L's Avatar
93f1505.0L
I have a superchip and added the a14.7 in there. Inoticed a little difference in her
Old Dec 12, 2008 | 10:11 AM
Talyn's Avatar
Talyn
Maybe the SuperChips don't do it.
I know if TW burns a chip for you, you don't need the resistor mod.
Old Dec 12, 2008 | 10:16 AM
kupiec20's Avatar
kupiec20
i dont tow anything, but iplow here in N.E. what would be my best bet 10K OR 14.7K
Old Dec 12, 2008 | 10:19 AM
Talyn's Avatar
Talyn
Depends on the truck man.
You'll have to try both and see which works better.
Some people here are running 26k.
Old Dec 12, 2008 | 10:38 AM
cowmilker08's Avatar
cowmilker08
is the mod your talking about the idm mod or something else.
Old Dec 12, 2008 | 10:47 AM
Talyn's Avatar
Talyn
The IDM mod is the BB mod.
The resistor mod fools the IDM. (I think its the IDM)
The resistor mod fools the truck into creating a higher fuel pressure.
The BB Mod creates more oil pressure.
Aww poo, memory went to crap. =\
Old Dec 12, 2008 | 11:24 AM
cowmilker08
ok im more confused now
Old Dec 12, 2008 | 11:39 AM
spazinweasel's Avatar
spazinweasel
im not sure but i think thats the other way round the bb or fpr shim is fuel and the resistor is oil ......i think
Old Dec 12, 2008 | 03:09 PM
c00nhunterjoe's Avatar
c00nhunterjoe
bb and fuel pressure mod are the same. i run the superchip with a 14.7k, my truck is happiest with that combo.
Old Dec 12, 2008 | 04:32 PM
Talyn's Avatar
Talyn
You mean the resistor mod and the BB mod are the same thing joe?
Old Dec 12, 2008 | 05:53 PM
JethroF250's Avatar
JethroF250
the resister mod is for the icp. it regulates how much pressure is pushed through the injectors. right now i am running 20k on icp the resistor on eot is for engine oil temp. the higher the resister in ie: 4.7 8 10k determines how cold the pcm comp thinks the oil is.i found 4.7k is best for my truck if you put a resister in the eot plug wire then it will trick the engine to thinkin the oil is cooler than it really is which in turn advances the timing. the bb mod deals with the fpr (fuel pressure regulator) if your fuel pressure reading is low stick a bb on the end of the fpr spring and it raises the pressure. should be round 70 or 80psi. finally the idm mod is when you swap out one of the resisters on the idm (injector drive module) if done corresctly you will boost your volts up to 140 which is higher than a SD i believe. hope this helps you guys out
Old Dec 12, 2008 | 05:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
No they are not the same thing. The BB is for shim the FPR, the resistor mode could be for the ICP or for the IDM, both are also different modes.
