Sponsored by: Real Truck
Getting manifold studs out sucks!
Old Dec 11, 2008 | 08:11 PM
bad466's Avatar
bad466
Putting Motorsport headers on my 5.4, job wouldnt be too bad if the old studs werent so hard to get out. Got them all out except the lower rear one on the passenger side. It was broke off about a 1/8 inch inside the hole. I drilled through it then let it soak in aero kroil for a day, went out tonight and tried to back it out with an easy out and it broke off. What a pain in the *** this job has turned into. I hope its worth it!!
Old Dec 12, 2008 | 12:10 AM
patrickke's Avatar
patrickke
let us know when you get em on and tell us about the power gain you got out of them
Old Dec 12, 2008 | 05:36 AM
50jd60's Avatar
50jd60
Have had great luck with the left handed drill bits for broken studs, better then the easy outs that are to easy to break...
Old Dec 12, 2008 | 07:45 AM
Boris2000's Avatar
Boris2000
Get a die grinder and chamfet the edge of the hole. (cylinder) Weld a nut to the end of the broken stud/easy out. and turn back and forth. It may take a few nuts, but you can get them out. I don't really like easy outs, to me most of the time they make things worse.
Old Dec 12, 2008 | 11:40 AM
Serg450's Avatar
Serg450
So much for the name easy out.
Old Dec 18, 2008 | 08:38 PM
bad466's Avatar
bad466
Just an update, headers are on and I had a full dual exhaust bent for it, no convertor, with a pair of Dynomax race magnum mufflers. It made quite a difference in power, I will post when I run a whole tank of gas through it to see if the mileage improved. If anything it sounds a hell of a lot better than it did stock.
400Nut
Modular V10 (6.8l)
35
Nov 2, 2013 03:01 PM
michaelmueller
Modular V10 (6.8l)
Aug 10, 2008 05:10 PM
fredweberjr
Mar 16, 2008 07:08 PM
jeffster442
Aug 29, 2007 08:05 PM
aswecit
Garage & Workshop
Jul 7, 2002 07:33 PM
