Sponsored by: Real Truck
4x4 problems still
Old Nov 30, 2008 | 08:18 PM
nicksgt's Avatar
nicksgt
4x4 problems still
Theres is now power going to the actuator on the T-case has anyone had this problem? The dash light dosent come on either. Anyone know what fuse it is ?
Old Dec 1, 2008 | 12:36 AM
Steve_250's Avatar
Steve_250
On what vehicle? Your 1999 Explorer that you have listed?
Old Dec 1, 2008 | 04:01 PM
nicksgt's Avatar
nicksgt
Sorry its an 02 f350
Old Dec 1, 2008 | 04:41 PM
Big Orn's Avatar
Big Orn
It's under the hood - number 111, 30 amp maxi-fuse.
Old Dec 1, 2008 | 04:49 PM
06silvercrew's Avatar
06silvercrew
Look under the hood on the drivers side. THere is a small relay box that houses two relays for the 4x actuator. I had one of the terminals back out out so it wasnt making contact with the relay. I had the exact same symptoms as your describing. Thats the first place I would check.
Old Dec 1, 2008 | 05:48 PM
nicksgt's Avatar
nicksgt
Ok thanks guys Ill check once the wife gets home with the truck lol
Old Dec 9, 2008 | 08:51 PM
nicksgt's Avatar
nicksgt
Theres 4 relays under the hood any idea which one it is? Where can I get a wiring diagram? Some one told me that its common for the switch to go on the lariat editions, I dont understand how the switches would be any different has anyone heard of this?
Old Dec 10, 2008 | 06:42 PM
nicksgt's Avatar
nicksgt
Anyone have any ideas or ever hear of this?
Old Dec 10, 2008 | 09:03 PM
06silvercrew
If your seeing 4 relays then your not in the right spot. Look on the INNER fender ahead of where your seeing the 4 relays and you will see a small blak box, take the cover off it will house the 2 4x4 relays. No the switch is NO different from lariat to a base model. Read my post from before, check the connections in the relax box, thats where my problem was.
Old Dec 16, 2008 | 08:06 PM
nicksgt's Avatar
nicksgt
Well theres no power going to the switch either, What im looking at is two boxes one has 2 realys the other has one with 2 smaller ones in it not sure if its realys or what. I bought one new realy and tried it on all 3 of the spots they all have the same part number. But there is still no 4x4. Im clue less now I dont know what else it could be.
Old Dec 16, 2008 | 08:30 PM
06silvercrew
I would check the 4x4/gem for codes.
Old Dec 18, 2008 | 05:29 PM
Beerstalker's Avatar
Beerstalker
Can you take a picture of the relays under your hood that you are looking at?
Old Dec 18, 2008 | 09:33 PM
jasowiii's Avatar
jasowiii
I can't find the relays either.
My manual lists them but the number on the list does not show up on the location diagram.
I have 3 boxes under the hood on the drivers side.
1 big one with a butt load of fuses and 3 big/3 small relays
2 small ones, each has 2 one inch cube relays, all 4 the same part number.
I played misical fuses with all except the smaller fuses in the big box.
Anyone know if I swapped the ESOF/Transfer case motor relays or not???
The motor still does not turn.
