Broken water pump stud
Old Aug 24, 2007 | 07:56 PM
jeffster442's Avatar
jeffster442
I broke the end of the stud off trying to remove it. How do you get the broken piece out now? I am not sure if it even screwed out at all. so not even sure I can get the timing chain cover off. HELP
Old Aug 24, 2007 | 08:15 PM
89frankenford's Avatar
89frankenford
first off welcome. second, what is your truck and engine? and is the bolt still sticking out a little bit?
Old Aug 24, 2007 | 09:03 PM
jeffster442
92, 302, location ,lower left side. it is the stud that has a nut on the outside it goes through the bracket, that holds the A/C & power steering pump.
Old Aug 24, 2007 | 09:05 PM
jeffster442
LOWER RIGHT SIDE, darn key board
Old Aug 24, 2007 | 09:06 PM
jeffster442
Cool
F-150 and it is broke off in the housing. I can not see or get a bite on it
Old Aug 24, 2007 | 09:42 PM
Talyn's Avatar
Talyn
There is an edit button for you to use, so you dont have to post a few times.
Welcome to our forum.
Im' currently having a simmilar issue.
I hope somebody can help us soon.
There are many solutions, but i'm sure somebody here would know the best one.
Old Aug 24, 2007 | 09:57 PM
89frankenford
well what i would do is soak the broken bolt with penetrating oil like pb blaster or some other brand....NOT wd40 its not strong enough. then go and buy a reverse thread drill bit thats about half the size of the hole give or take. then carefully and slowly start drilling (IN REVERSE so the reverse drill bit will be actually drilling into the bolt) into the center of the bolt. what should happen and happens MOST of the time but not all is the reverse thread will start to go in and the bolt will unfreeze from the threads and it will just unscrew from the housing. thats what i did on a Chrsyler Concorde at the shop i work at and it worked great. worse case scenario that will just drill right through and you will need to buy a new bolt/stud and rethread the hole but thats worse case
Old Aug 25, 2007 | 11:45 AM
grizz3000's Avatar
grizz3000
89frankenford is right. They sell complete drill-out sets for this purpose. I've had good luck with them. The key is patience and to dirll straight down the middle of the bolt. Soaking the bolt at least a couple blasts each hour for a few hours before you try it helps too.
Good luck. Been there, done that.
Old Aug 25, 2007 | 03:13 PM
Talyn's Avatar
Talyn
I'd try and use an easy out, or some other method before a heli coil.
Old Aug 27, 2007 | 09:44 AM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
I would try the reverse drill bit first, before trying the easy out. If you break off the "easy off" in the hole you will have drilled in the bolt, you will have complicated your problem.
Old Aug 29, 2007 | 07:43 PM
jeffster442
It is fixed. we had to use a tap and heli -coil. the original stud was broke off in the block and easy out could not reach it. then used a shorter bolt to bite the threads and bamb. water pump back on. thank you one and all for the advice. this site rocks. Jeff
Old Aug 29, 2007 | 08:05 PM
otee453's Avatar
otee453
I don't like trying to drill and ez out a broken bolt if the bolt is siezed. If you break your ez out, now your really up the creek. Spot weld a welding rod or some other stud to the stub, heat the area where it is seized and back out with vice grips.
Bolts seized in around the water pump area will come out like nothing with some heat.
SilverE350
Aug 6, 2011 10:55 PM
beagledog
34
Jul 13, 2010 10:26 AM
KWest
Jun 20, 2010 03:21 AM
kaduh
Nov 17, 2009 04:08 PM
stevef100s
General Automotive Discussion
Jun 2, 2004 02:39 PM
