AA code injector in a 99?!?!?
Old Dec 11, 2008 | 07:34 PM
GrizzlyPiet's Avatar
GrizzlyPiet
So i got my new injector from Alliant Power yesterday and had a few hours to swap it out.
I have been experiencing a miss at about 1500 rpm. The last time this happened my #2 inj was not putting out any fuel even though the solonoid ohmed out fine.
Well I hooked up my new AE - I got it cuz i figured i'd rather not spend 8 hours tracing down wires again if there was a better way to do it!
Ran a buzz test and my #5 inj sounded very weak - barely a buzz even when hot.
So i pulled the PS VC - and what do i see in the #5 hole - a friggin AA code injector!!!!
Nevermind teh fact that only 2 of the VC bolts were even close to tight - i took off the rest without using any tools - just fingers - needless to say the PS side of the engine is pretty oily - not running drips but just oily dirt.
Oh well - I cant beleive that some one would have stuck an AA injector in there.
I have an EARLY 99 build date on engine is 02/02/98
so i should have AB codes with no LL in #8
Anyways, i have pictures of the injector and everything...
Really just wanted to vent!!!
I am hoping that after running a few miles to get all teh air out, that my truck will be running WAY better...
Ill post pictures when i get to a place where i can download them off the camera.
Old Dec 11, 2008 | 07:57 PM
cangim's Avatar
cangim
So did you put an AB back in?
Old Dec 11, 2008 | 08:01 PM
camojeeper's Avatar
camojeeper
if that injector had been rebuilt it wouldnt matter hat it said on top i.e you send your injectors to a shop and they send you back ab's or ad's its all about the parts inside not the numbers
Old Dec 11, 2008 | 08:14 PM
F350-6's Avatar
F350-6
Hey Piet. While you're under there, go ahead and re-torque all the rocker arm pedestal bolts to 20 ft-lbs, and the lower injector hold down bolts to 120 in - lbs. You'd be surprised how different the engine sounds with just a 1/4 turn loose injector bolts.
I've got no idea why you've got an AA injector under there, but you're right. Life is much easier when you just have to plug in the AE and press a few buttons.
Old Dec 11, 2008 | 08:44 PM
rebelchevy02's Avatar
rebelchevy02
Have you owned it since it was new? Wouldnt surprise me if it was swapped out. Like said above, Im not sure how revelant it is once you get a rebuilt injector?
Old Dec 12, 2008 | 05:20 PM
GrizzlyPiet
Chris - Yes I love the AE - Makes trouble shooting so much faster
Also i did torque all the bolts down - I had a few that were loose-ish i mean i could get about a 1/4 turn out before the click.
I had not thought about the possibility of a rebuilt....hmmmm i know that my #5 and # 4 were swapped out before i got the truck - they have an alliant power code not the OEM ford code/part number. Oh well, i guess it makes no difference now-I got my brand new Alliant Power AB code in there...
Oh yeah - No I am the second owner. Ive had the truck for a year now and i am just sorting out all of the lil bugs that arent quite right before i can start modding it.
kt19
Oct 27, 2014 05:37 PM
Jay Fletcher
Apr 7, 2013 10:33 AM
Tim Hodgson
65
Nov 30, 2012 01:22 PM
ccg711
63
Mar 20, 2011 09:58 AM
tobacco farmer
Apr 8, 2010 08:59 PM
