Manual glow plug conversion...
Old Dec 10, 2008 | 05:39 PM
hogdogs's Avatar
hogdogs
While under the hood of my father's 6.9 I got to lookin'... is the solenoid at rear of intake the glow plug solenoid? If so is it as easy as disconnecting factory wire to replace with a switch wire?
Brent
Old Dec 10, 2008 | 07:34 PM
tow.mater81's Avatar
tow.mater81
yes thats the glow plug solenoid. all you need to do is remove the switched power wire and replace it with your new wire for your manual switch
Old Dec 10, 2008 | 09:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What year truck?
There are two glow plug systems, that are completely different.
Do your glow plugs have spade terminals or pin terminals?
Old Dec 10, 2008 | 10:06 PM
hogdogs's Avatar
hogdogs
I will look when I see his truck again... I think he said it is 86 or 88...
Brent
Old Dec 11, 2008 | 11:09 PM
ford trans tech's Avatar
ford trans tech
unless you really know glow plugs a manual switch is an easy way to nuke $100.00 worth of gow plugs
Old Dec 12, 2008 | 01:40 AM
hogdogs's Avatar
hogdogs
My 6.2 GM had a manual switch and I just did a a "8- one thousand " count and fired her off good for several years... Now to train my father to this...
Brent
Old Dec 12, 2008 | 11:32 AM
Dave Sponaugle
The year break for the glow plug controller was 87, so the 86 and 88 would be two different systems.
87 was a bit confusing, most of them were the new style system but I have seen a few with the old style system.
But I have no way of knowing if that is how they left the factory.
68Mercury250Ranger
Oct 20, 2016 09:21 AM
sincecrazy
Jan 1, 2013 10:54 AM
99whiteford
Aug 24, 2009 03:00 PM
cornbinder
Mar 4, 2008 08:30 PM
LEEAMEN
Dec 18, 2007 12:49 PM
