Sponsored by: Real Truck
Transmission Flush Question
Old Dec 10, 2008 | 04:20 PM
BMWM1's Avatar
BMWM1
In this guide I found in the tech section it never explains what I'm suppose to do with the hoses I hook up?
Truckblog - How-To Flush Ford's Torqueshift Transmission
Old Dec 10, 2008 | 04:33 PM
david0505's Avatar
david0505
Have You priced this job at Your local dealer? after pricing the fluid and looking at the job and the problems getting a good,complete flush,I had Ford do it,total was about $150and I Have that Ford receipt, just in case. Dave
Old Dec 10, 2008 | 04:37 PM
BMWM1's Avatar
BMWM1
I understand your point.I even know some of the guys that work there and I would prefer to do the work myself.
Old Dec 10, 2008 | 04:50 PM
mwsF250's Avatar
mwsF250
Not sure what they are doing exactly... the way I do it, I only need 1 hose. That hose goes from where the fluid is pumping out of the tube into a 5 gallon bucket to capture the old fluid.
I add fluid through the dipstick. I can't add as fast as it pumps out, so need to have someone inside shut the engine off the when the outlet starts spitting air along with old fluid.
Could be they are using the second hose for that, for refilling with fresh fluid?
Old Dec 11, 2008 | 01:29 AM
BMWM1's Avatar
BMWM1
Im not sure either.It seems as if a whole section is missing from the diy instructions or Im just not reading it correctly.
Old Dec 11, 2008 | 06:46 AM
aldridgec's Avatar
aldridgec
You have two hoses because you don't always know which one is the output. Stick them both into the bucket and you're safe!
Uh... just looked at that link. Dunno, something is definitely missing.
Old Dec 11, 2008 | 12:47 PM
BMWM1's Avatar
BMWM1
Someone should remove that from the tech folder if its not a complete set of instructions.Just .02 worth
Old Dec 11, 2008 | 05:10 PM
mwsF250's Avatar
mwsF250
One tip: Fasten the hose to the bucket or have someone hold it.
Some AT's pump the fluid with enough volume and pressure to turn the hose into the whipping, flailing jet of slippery goo.....
No, I didn't take pictures or catch it on video. Bummer, as I can actually laugh about it now (10 years later).
Old Dec 13, 2008 | 07:32 AM
stevenn1's Avatar
stevenn1
5R110W TorqShift transmission
There are 2 filters on it? One internal & one external. Anyways, it says to replace the old fluid with new fluid according to the exact amount of old fluid that came out, but what if your trans was already low on fluid - then when your done it will still be low on fluid. Also Truckblog calls it a "Torqueshift®" & Ford calls it a "TorqShift®", not being picky but for several reasons I dont think Truckblog really knows what they are talking about.
Old Dec 14, 2008 | 02:55 AM
BMWM1's Avatar
BMWM1
I agree.Having missing information is worse then no information...
Ryan50hrl
2004 - 2008 F150
21
May 18, 2010 02:03 PM
JimBrazil
Nov 14, 2009 06:42 AM
builtfordtough13
Mar 19, 2008 10:17 AM
yankee88
May 15, 2004 07:02 PM
