Sponsored by: Real Truck
Please Help. I have a Cold Start Issue....
Old Dec 9, 2008 | 07:45 PM
T.R.Bauer's Avatar
T.R.Bauer
Hi guys. I really am scratching my head and out of ideas.
Truck: 2000 7.3 diesel 4x4 dually
Problem: difficulty starting when cold
What it does:
1.) When turning on the key, the wait to start light comes on, but the volt gauge does not show a load like the glow plugs are on.
2.) Then, I turn the key about 5 cycles and let the corresponding supposed glow plug rotations run their course, and try to start it and is just turns over and over. Then, all of a sudden the volt guage drops and I wait for the glow plug to actually get hot now that they are getting power and it starts right up. And I mean right up.
3.) Then, I can turn it off and cycle the key and the glow plugs still load the battery and it of course starts just fine.
What I have done:
1.) New batteries and they test just fine.
2.) New GPR and tested the new one; it works perfectly.
3.) Cleaned all connections.
4.) Repetitively cursed at it......
5.) If jumping the relay to heat the glow plugs it starts right up every time.
Any ideas?
Old Dec 9, 2008 | 07:55 PM
fxstbchopper's Avatar
fxstbchopper
Sounds like the new relay is working intermittently or it is not getting the signal to switch on from the PCM. Have you tested the relay when the battery gauge looks like the glow plugs did not fire I would check to see if the glow plug side of the relay had battery voltage when that happens.
Old Dec 9, 2008 | 09:08 PM
T.R.Bauer's Avatar
T.R.Bauer
Thanks for the response. I have tried a couple of different GPRs. It does the exact same thing every time.
Honestly, I am stumped.
Thanks,
T. Bauer
Old Dec 9, 2008 | 10:04 PM
fxstbchopper
Sounds like it is not getting the proper signal from the PCM. Why I am unsure but I am thinking which may not do any good either LOL..
Old Dec 9, 2008 | 10:07 PM
fxstbchopper
The only other things are the oil temp sensor and the barometric pressure sensor are also in the glow plug system so it could be one of them has went bad.
Old Dec 9, 2008 | 10:11 PM
T.R.Bauer's Avatar
T.R.Bauer
I have no codes. Don't those throw a code?
Old Dec 9, 2008 | 10:21 PM
fxstbchopper
No I don't believe they do the only things in the glow plug system that throw codes are the glow plug circuits.
Old Dec 9, 2008 | 10:24 PM
fxstbchopper
Also to help out there is a 7.3 section on here you will get more responses there. That is where I usually am.
Here:
https://www.ford-trucks.com/forums/forum31/
A lot of good knowledgeable people over there not that there is not here but there a lot more 7.3 people over there that don't come over here.
Old Dec 9, 2008 | 10:30 PM
aldridgec's Avatar
aldridgec
You need to find what part of the glow plug relay circuit is failing, the power or the signal. If it is fairly repeatable, you can check to see if the glow plug relay is getting the signal, or if the relay isn't closing.
Old Dec 10, 2008 | 08:27 AM
T.R.Bauer's Avatar
T.R.Bauer
I have power to the relay on the main feed from the battery. I also have power on both of the little ones. According to my ford book, this is how it is supposed to be as it says that the PCM grounds the circuit. So, how does one test the oil temperature switch? Is there an ohm test?
Old Dec 10, 2008 | 09:16 AM
aldridgec's Avatar
aldridgec
You will have power to ground from both of the little ones. The power flows through the internal coil to the ground input side. Basically the power is stopped in the ECM. When the ECM grounds the circuit, it allows the power to flow through. You need to see if the ECM is grounding one of them. You will see one of them drop voltage if/when the ECM grounds it.
Old Dec 10, 2008 | 10:38 PM
T.R.Bauer's Avatar
T.R.Bauer
It does ground them. They work. But, not on the first turn of the key. After a few cycles (around 5) they come right on and it starts like new. I am stumped......
