Tires "General Grabbers" anyone have any problems
I have a 2000 Ford F-350 4x4 lariat dullie with these General tires on it and one blew out. The other one on that side is ready to blow out. the tires seem to be splitting in the area of the rim. the other side is starting to crack and some bulges are present. I was wondering if anyone else is having any problems.....
My guess would be that you had better check the weight rating on the tires, also are they weather checking? there is a good chance that they might be a C rated tire, even some D's are too light for a loaded one ton. Good Luck
F-250 now 350 4x4 ext cab SB Green Monster (Used to have)205000 miles, Mass air 460 w/ performance heads, E40d to 5spd conversion, 205 T-case, 4.11 gears, Power-Lok equipt dana 60 front, Doug Thorleys and swapped in EFI 33 gallon bronco rear tank. 33's on 16x8" Outlaw II's, Truck is destined to be a 5.9L cummins diesel 5spd.
Ford11
1999 to 2016 Super Duty
23
01-24-2021 12:06 PM
gvaz
07-30-2006 08:49 PM
