Sponsored by: Real Truck
Front end Question
Old Feb 28, 2014 | 03:25 PM
250-FX4's Avatar
250-FX4
Question Front end Question
I have a 2010 F250 SD FX4 package. I had to have the rims replaced due to one of the having a crack in it after I had my tires replaced. The problem that I am having now is that before everything was nice and tucked in in the fender wells, now my driver side front tire sticks out about an inch and a half further that the other tires. Nothing has changed except the rims and the other 3 tires still sit in the wheel wells just as the factory. Any help or suggestions on this problem would be a great help.
Old Feb 28, 2014 | 06:30 PM
2stepn's Avatar
2stepn
sounds like your replacement rim has the wrong offset.
Old Feb 28, 2014 | 06:46 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch
wrong offset, at least thats what it sounds like, you dont have any abnormal noises do you?
Old Mar 1, 2014 | 01:30 AM
250-FX4's Avatar
250-FX4
Nothing abnormal to say going back to Discount Tire in the morning to have them to relook at what was ordered and to double check the offset on that particular rim I will you up to date as I find out more. Thank you again for the quick response.
Old Mar 3, 2014 | 07:17 PM
250-FX4's Avatar
250-FX4
OK quick update Went back and they double checked the off set on that rim and then the other ones just to make sure that they were all the same, and they were so now it's off to the dealership to put it in the shop and find out what they can tell me.
Old May 18, 2014 | 12:09 AM
250-FX4's Avatar
250-FX4
Just another up date sorry it took so long to get back with everyone. Work has been running me ragged. But the answer to my own question was that the tract bar was bent. this was caused the person the put on the leveling kit not using all parts. The relocation bracket was not put in so that was the reason for the tire pull.
Tony Sparacia
2009 - 2014 F150
Dec 19, 2018 06:11 PM
Hotpocket
Feb 4, 2011 02:52 PM
2000ca250
15
Jan 16, 2010 03:48 PM
NV250
Sep 25, 2008 03:56 PM
william_ace
Jan 24, 2004 06:48 PM
