Hot Shot Secret?
Long version: I bought it, buying into their advertised part about guaranteeing money back if it didn't work or you saw no improvement. I put it in the truck on a fresh oil change, and never saw any difference in the way the truck ran, mileage, starting ease, nothing. Ran it the whole oil change, something like 5000 miles and when I had my oil tested, the results looked exactly like normal oil. I even mentioned the additive when I submitted the sample so they would look for something extra, but the lab found nothing.
So, with it not working at all for me, I tried to contact them to get my money back. I could not find any "official" method for requesting a refund, so I placed multiple phone calls and sent multiple emails, none of which ever got answered. I made it clear that the product did not work for me, politely though, and would like a refund, so they knew what the deal was. Never ever got any type of reply or phone call returned.
I chock it up to me getting suckered out of $50 and a lesson learned. However, I personally will steer anyone away from using it, based on my results with it not working and my experience with their bad business practice.
Edit: I see Brandon has mentioned others who had the same experience as me.
I beleive this stuff was designed specifically for the 6.0 and its injector sticking problems. Another reason Im glad my 6.0 is history!
Don't waste your money on that either, bought the whole song and dance and tried it. Said it [U]SHOULD[U] last about 10K miles... Nope, what little I was getting when out with the oil change.
Now I did have a friend that owed me a can of 44K from a deal I got him on some injector work. Well on the way home from Branson, MO I put it in and got the best mileage I have ever gotten 22mpg... Have never seen it before or since. Do not ask me why or how come, but I did record that for mileage.
Doc.
good for a 6.0
futile for a 7.3
I'll post back in a few days with results. I am going from Ford's 15-40 dino to Rotella syn 5-40 though so I do expect to see a big difference. I wanted Shaefers 9000 but closest rep is 1.5 hours away. I asked about price with shipping and never heard back... Anyone know where to order online?
I'll say this about the Schaeffer's though...I honestly believe it helped to clean out my engine better than anything else. My UOA's showed it cleaning it out, but the biggest thing I noticed was the truck running smoother. I inquired with a rep about that and he told me that Schaeffer's oil has a great detergent package that is designed to remove old sludge and buildup left behind from other oils. Just an FYI for any of you with what you believe to be a sticky injector or two.
I decided to try HSS (even though it mentions it's for 6.0L Engines) after 213,000 miles with injector and power issues slowly making themselves apparent. A phone conversation with Chris and some change later, it was at my door in about a week.
One thing he did recommend I do, was to run my truck on the safest, highest tune to help clean things out a little better. (on my SCT its the 120hp/200tq tune) I did and between the 404 firepower (fuel) and HSS (oil) it really cleaned things up. It's like I have a whole new set of injectors. It wasn't a right now kind of difference though, it did take some time as I expected it to.
To put things to the test, I drove up to Dallas on business just to see how the engine would perform and the results were shocking. The engine was soooo quiet, all I heard was the slight whistle of the turbo as I climbed a hill and that's it. Mileage wise, my truck (lift, tires, and all) will give me about 17-18 mpg on the run to Dallas. I went to fill up when I got back and was shocked to see that I got 19.6 mpg. That was within about 1,000 or so miles since the last oil change. So within the first 1,000 miles, it made a real difference.
Needless to say, my cold starts (as in 35 degrees cold and colder) are if it's a warm day out (no loping), much smoother idle, acceleration, and better mileage. As I said, it worked for me and from the feel of things is still working.
Jeremy, did you try it before you switched over to Schaffers, or had you been running that for a while? A question for those of you who have tried it (aside from Toreador_Diesel), were you having problems with your injectors that you were trying to cure?
I've never been a fan of an oil additive in the 7.3, but was just wondering if some of you who tried it were trying to fix something that wasn't broke. That could explain the lack of results. Our injectors can't be that much different then the 6.0 injectors, so I don't understand why it would work on one and not the other. I would have guessed it wouldn't work on either one.
Of course the stories about not honoring the guarantee tells a whole different story. If they stood behind the product, then it might be worth a last ditch effort for someone who couldn't afford a new injector(s).
It would be nice to hear more feedback from others who have used it on the 7.3.
https://www.ford-trucks.com/forums/6...ml#post4647790
Not lookin' too good, especially for an FTE sponsor.....
Pop
