Sponsored by: Real Truck
Lightning exhaust ?
Old Dec 9, 2008 | 11:15 AM
bad466's Avatar
bad466
Lightning exhaust ?
Anyone ever try putting a complete Lightning exhaust on their 5.4 powered Super Duty, im talking from the manifolds back. I think im gonna try it, just curious if anyone else here has already done it.
Old Dec 9, 2008 | 02:37 PM
patrickke's Avatar
patrickke
never seen it done...if you do it....do a write up.....are you gonna use an aftermarket borla or the stock svt exhaust?
Old Dec 9, 2008 | 02:46 PM
ReAX's Avatar
ReAX
I can't think that the manifolds are significantly different enough to make any power on a N/A motor, and the OE exhaust is probably just comparable to a decent aftermarket. I don't want to discourage you, but what are you expecting to gain?
Old Dec 9, 2008 | 04:54 PM
rollerstud98's Avatar
rollerstud98
Sound maybe?
Old Dec 9, 2008 | 05:42 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yeah why not just buy a nice aftermarket exhaust...
seems like a better use of ur money and i bet it would easily outdo anything the stock Ford Lightning exhaust musters...
Old Dec 9, 2008 | 08:04 PM
Stewart_H's Avatar
Stewart_H
I assume you're thinking of doing this on a regular cab 2-wheel drive F250? Even then, I'd be surprised if they fit. The bends and curves of the pipes won't be in the correct location.
Remember, the Gen 2 L's are a regular cab configuration on the smaller, F150 platform. And the exhaust is a side exit (passenger side) setup.
If your truck is a 4x4 you'll have no chance of it bolting right in.
Stewart
Old Dec 9, 2008 | 08:29 PM
bad466's Avatar
bad466
I was just gonna try it because I have a brand new convertor pipe off of the lightning. I found out tonight it wont work. Im in the process of finishing putting a set of shorty headers on it and just really didnt want to put the restrictive y pipe back on it. The factory exhaust really looks like it chokes these trucks.
Old Dec 9, 2008 | 10:36 PM
patrickke's Avatar
patrickke
why dont you run it like the lightning exhaust out the side with dual outlets and some nice chrome tips
Old Dec 10, 2008 | 12:10 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Another thing to think about would be the catalytic converters. The F150 is a fully OBD-II compliant vehicle, while the 2001 F250 in your profile is only OBD-I. It will/might not have the O2 sensor after the cat, and the Lightning should have TWO cats and FOUR O2 sensors.
Old Dec 10, 2008 | 01:02 PM
rollerstud98
When did the F250's switch over to OBD-II?
Old Dec 10, 2008 | 01:34 PM
krewat's Avatar
krewat
For the gassers, I'm pretty sure it was across the board when the engines went 3-valve.
There are, however, reports of F-series trucks with California emissions (and those that aren't supposed to be) that have the third O2 sensor after the catalytic converter, which means they are (supposed to be) fully OBD-II.
I've also heard about Excursions setup that way too. I think they mostly have EGR valves too.
In some of the "green states" that follow the California emissions model (NY/MA/VT/ME I think) it's hard to get an OBD-I F-series to pass because there's no O2 sensor heater monitor, and no catalyst monitor. New York is one of them. If the inspector doesn't know to put in a weight code of over 8500 lbs for a passenger-plate pickup, it won't pass when the computer reads the OBD system.
Old Dec 10, 2008 | 01:48 PM
rollerstud98
That is pretty interesting, glad I don't have to go through that where I live.
Old Dec 10, 2008 | 01:55 PM
Stewart_H's Avatar
Stewart_H
That's invaluable info for guys in those states!
Rep points given!
Stewart
04SilverSCFX4
2004 - 2008 F150
Oct 4, 2004 06:16 PM
silfox1
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 16, 2004 09:45 AM
OD1010
Mar 28, 2004 01:13 PM
Lightning Fan
Feb 12, 2004 08:14 PM
lightningwannabe
Apr 2, 2001 06:21 AM
