Sponsored by: Real Truck
Shock mount broke
Old Dec 9, 2008 | 06:35 PM
jamie7375's Avatar
jamie7375
Shock mount broke
while replaceing my rear shock, I broke the bolt off of the top mount that is riveted to the frame...any help would be great,,,
Old Dec 9, 2008 | 06:46 PM
jjcomputer's Avatar
jjcomputer
the shock mounts I've done in the past have been available from Ford for a reasonable price ($18.00 a piece or so rings a bell on my old 80's vintage trucks). Air tools or a torch are the best way to get the rivets out but an electric drill and a cold chisel will work too...Drill a hole almost as large as the rivet shank diameter through the rivet and cold chisel the head off. Replace the rivets with bolts and nuts Grade 5 or better and your back on the road.
Old Dec 9, 2008 | 06:47 PM
WestxSRT10's Avatar
WestxSRT10
Can you get a Saw's All blade up there?.... maybe cut the bolt as close to the shock as you can to get a vise-grip on the stub. Theres always heat or w-40 at that point.
Old Dec 9, 2008 | 06:50 PM
jamie7375's Avatar
jamie7375
No way to cut it out. ill call the ford dealership and I have a friend that has a frame shop that i can get to cut the old brace. Hope that works. Thanks for all the help guys...
Old Dec 9, 2008 | 07:37 PM
jamie7375's Avatar
jamie7375
Does anyone make an aftermarket replacement for the upper rear shock mount????Rather do that than go to the "stealership"...
Old Dec 10, 2008 | 12:01 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
For Ford-only parts, contact FTE/PARTS-GUY or go to y2kford.com and click on Parts, Order Parts.
He discounts dealer parts pretty well...
Old Dec 10, 2008 | 02:38 PM
Fordflanigan's Avatar
Fordflanigan
my rear shock mount stripped out on my old 01 f250. I cant remember exactly how i fixed it but i believe i cut the bolt as close to the frame as i could. Then i drilled a hole through the frame as close to the origianal mount as possible. Then i used a grade 8 bolt that was the same size as the origianal mount. I forgot how long the bolt was, probly about the same size as the original with the addition of the frame thickness included. My first time i used a bolt with threads the whole way, that bent its first time off road so i replaced it with the same size bolt but the thread only reached to the end of the shock bushing the rest was smooth. (Im not sure what the name for this type of bolt is). This bolt worked fine and held up through heavy offoard use.
Kind of an okie fix but hey it worked
strobewylan
Jun 26, 2017 01:57 PM
rockyrunner99
Apr 3, 2016 01:04 PM
wesley49
Jan 26, 2016 03:30 PM
stray
Dec 3, 2015 04:47 AM
Fordmaster06
Jun 25, 2012 10:02 PM
