Fuel Line Quick Connect Clips (needed)
Old Dec 8, 2008 | 03:26 PM
ColeinDesoto's Avatar
ColeinDesoto
Smile Fuel Line Quick Connect Clips (needed)
NOTHING AVAILABLE IN SEARCH...I have a 1986 F250 Lariat XLT 4x4 with dual tanks. I replaced the Fuel selector valve 3 Port 2 wire TYPE. The fuel lines are the quick connect type with the hard plastic fuel lines. The connectors have plastic clips that fit over the nipples of the valve and keep the lines from coming off. anyway I broke 2 of the 3 clips. Does anyone have a part number and a Vendor that would stock these, I would hate to rig up a hose and worm gear clamp to correct this. Many thanks.
Old Dec 8, 2008 | 04:04 PM
Franklin2's Avatar
Franklin2
You might want to try autozone's site. I put in "fuel clip" in a search and several came up, some without pictures though.
Old Dec 8, 2008 | 04:09 PM
ColeinDesoto
Thanks, I'll try
Hard to get to all the Part's websites, And the info is vauge for the most part, Our local parts house CarQuest did not have a clue what i was looking for. I'll try these guys Thanks
Old Dec 8, 2008 | 04:18 PM
bashby's Avatar
bashby
If its what I think, you get 2 of them with a fuel filter. I remember there being 2 sizes, the black ones and white. White comes with the filter. The ford dealer should have them, at least thats were I got them 10 years ago or so. you can also use a zip tie, they are about as strong as the clips. Kinda hard to explain how I've done it but I could try if you dont understand what I mean
Old Dec 8, 2008 | 07:35 PM
ctubutis's Avatar
ctubutis
Originally Posted by ColeinDesoto
...I would hate to rig up a hose and worm gear clamp to correct this. Many thanks.
I had absolutely no problem installing rubber fuel line + hose clamps in place of the
molded lines (which utilize those quick-connect things) the factory had installed on my
daily driver when I had to replace the fuel pump last summer. I'm sure you can prolly find
'em in a Help catalog at an auto parts store. Or, go to a Ford dealer as someone already
suggested, they may have 'em in stock.
-ct
Old Dec 8, 2008 | 07:39 PM
Franklin2's Avatar
Franklin2
I like the wire tie idea myself. I am going to file that away and try it sometime.
Old Dec 8, 2008 | 11:16 PM
86Stepside's Avatar
86Stepside
I know Napa has them, I just bought some about a month ago.
Old Dec 9, 2008 | 04:07 PM
JPETRO1051's Avatar
JPETRO1051
Auto zone / Napa will have the clips. In a jam i think fram supplys them with their 3802 gas filter.
Old Dec 9, 2008 | 09:58 PM
PatBethea's Avatar
PatBethea
Last time I needed replacements (two or three years ago), I got them from my Ford dealer.
Old Dec 19, 2008 | 08:35 PM
ColeinDesoto
Thanks
This site is really great, I appreciate all the INPUT, I was able to locate them at NAPA.
I will try to monitor the threads more closely, as I can assist those in need as well.
Again thanks you A-LOT
Poppa Squirrel
Nov 17, 2015 08:46 PM
jbd2003ranger
1983 - 2012 Ranger & B-Series
May 5, 2015 07:38 AM
OldWoodsDiesel
Dec 23, 2013 02:30 PM
