Cold weather/ Fuel problems
Old Dec 10, 2008 | 11:12 AM
fmr9's Avatar
fmr9
Maybe your tank is rusting internally or you picked up a bunch of debris from one of your fill ups. Might be interesting to carefully cut the old filter open to see if it has a lot of rust in it.
I usually change the filter about every 20,000 miles. that works out to around 2 years for me.
It is possible that lisagould's explanation about condensate freezing in the fuel pump relay is what caused your pump to not run and the truck to not start.
My truck has been difficult to start for the last 2-3 weeks, but only when the temp dipped below freezing. My hearing is pretty bad, but It didn't sound like the fuel pump was coming on when I turned the key. Eventually it has always started, and runs fine. I could not think of a logical reason for this to happen, but the freezing pump relay fit the symptoms. It eventually starts when the heat from the relay coil thaws the relay.
It might not be the problem, but I kind of think it is.
Good Luck Frank
Old Dec 10, 2008 | 11:56 AM
rostena's Avatar
rostena
Originally Posted by quicklook2
every 2 years is a good idea.
are you saying in went bad since march?
that is not normal.
Yea i guess. It wouldn't suprise me if i cut the old filter open and found rust. About a month ago I replaced my tank becuase it was leaking due to a nice sized hole, which was caused by rust.
The filter i just replaced didn't seem nearly as pluged as I remember it being in March. Perhaps my fuel pump is getting a bit weak?
The truck is very high miled and I don't know if the pump has ever been replaced.
Last winter my truck would start when it was 10 bleow.
Old Dec 10, 2008 | 12:25 PM
quicklook2's Avatar
quicklook2
you replaced the tank but not the fuel pump?
Old Dec 10, 2008 | 02:59 PM
rostena's Avatar
rostena
That's corrrect. I realize now that i probably should've replaced it when I had the tank down. Oh well, it's not that hard to pull down. If it starts acting up agian I'll have to replace it.
Old Dec 10, 2008 | 04:39 PM
rostena's Avatar
rostena
Originally Posted by fmr9
thejon2524
I find it interesting that your first post was
"Saw the site, was interested, look foward to sharing information about trucks."
9 posts and 7 days latter it is
"Thread should be re-titled, truck doesnt run because im lazy. " '
How is that sharing information about trucks?
Sounds to me like Rostena is a young guy still in school. He might not have a lot of time, money, or knowledge. He came here for help which was smart. I don't think he is lazy.
Frank
Thanks, fmr9. What you say is true.
Old Dec 11, 2008 | 10:24 AM
fmr9's Avatar
fmr9
Picked up a fuel pump relay today, $13.50 well spent. When I pulled the old one I found if full of corrosion. Scraped the plug clean as possible and filled it with dielectric grease. Either the corrosion or moisture in the relay, or a combination, was causing my starting problem. (I Hope).
The old relay will get cleaned up good and after I'm sure it is dry, it will ride along as an emergengy spare.
Frank
Old Dec 11, 2008 | 11:25 AM
quicklook2's Avatar
quicklook2
if you carry a spare, then you will never need it.
if you don't carry a spare, you will need it.
murphy's law.
glad you are up and running.
milehi_350
34
Jan 2, 2015 07:12 PM
cowboy_up_07
Dec 14, 2014 11:01 PM
HoseDog
May 25, 2009 07:11 PM
bigtorque
Dec 15, 2007 08:05 PM
smurray
Nov 28, 2005 01:28 PM
