Sponsored by: Real Truck
Accelerator pedal calibration?
Old Dec 8, 2008 | 08:29 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
One thing I still find really annoying with my 06 350 (5.4) is low speed throttle control control. It's just about impossible to move from stopped to very slowly and smoothly. No response , no response, no response.. then a surge. Backing up to a trailer really sucks. Yesterday I was trying to back up just enough to get my lowered tailgate over a low cement wall, the last six inches to go the thing took off and slammed the hitch into the wall. Good thing the hitch was there, but I still felt like an idiot.
So, I'm about to take it to the dealer, but before I do..
I hear hints about an accelerator peal calibration procedure for the fly-by-wire units, and I've searched for anything like this, but I've not been able to locate anything concrete. Is this real? Does anyone have a documented procedure or a link for this?
Old Dec 8, 2008 | 09:11 AM
motown's Avatar
motown
I do it on my 05 with 5.4L. You turn the key to the run position. Let the dash gauges stabilize. Then slow and steadaly push the accelerator pedal all the way to the floor. Then let up on the pedal, and turn the key to off. You can now restart the truck.
Old Dec 8, 2008 | 11:00 AM
Citypol86's Avatar
Citypol86
I had a similar problem with all acceleration. Have the dealer check TSB 06-04-08 for surging. It fixed my problem.
Later...
Brewster...
Old Dec 8, 2008 | 01:09 PM
NewEnglandHerdsman
thanks motown... Where did you learn of this procedure? Have you seen in it in a service manual somewhere?
Old Dec 8, 2008 | 01:10 PM
NewEnglandHerdsman
Later...
Brewster...
Thanks Brewster.. I'll be sure to mention it to the dealer if I need to go to them... Did you have the PO455 code, or just the surging?
Old Dec 8, 2008 | 02:03 PM
Citypol86's Avatar
Citypol86
Just the surging but it was any time I accelerated.
Old Dec 8, 2008 | 03:45 PM
motown's Avatar
motown
It was on a thread on the F150 side. I would do it on my 04 F150, every once in a while. It is a know service procedure for Fords. Your teaching the limits of travel, for the accel by wire.
Old Dec 8, 2008 | 07:34 PM
Go Devil's Avatar
Go Devil
Does this really work on the Super Duty? I have always thought there was little response from the accelerator pedal but belived it to be the 6.0 PSD in the low RPMs.
Old Dec 8, 2008 | 09:23 PM
motown's Avatar
motown
If it has accel by wire, I would think that it would work. The computer has to know its range of motion, including the lower & upper stops. This is so the computer knows what position the pedal is at, when being depressed.
Here is a link to the thread, where I found out about this:
https://www.ford-trucks.com/forums/4...djustment.html
Old Dec 9, 2008 | 05:56 AM
NewEnglandHerdsman
Thanks motown.. rep for you...
Old Dec 9, 2008 | 08:22 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I remember you asking about this before, didn't I give you a direct link to the TSB
Old Dec 9, 2008 | 09:16 AM
NewEnglandHerdsman
Quite likely yes Art - thanks. I probably already had it noted somewhere. I'm trying to avoid going to the dealer unless necessary. Even though it'll be under warranty, it's still a PIA - shuffling vehicles, getting rides, not having the truck, or sitting around waiting... So I wanted to chase down this calibration procedure, see if it was real, and try that first... Plus, according to OASIS, the truck was in for warranty service for another issue 12/2007 and was upgraded to the latest PCM level then, so there's a good chance the update spec'd in the 06-4-8 TSB is already in place. I may be just delaying the inevitable, but due to time constraints going to the dealer is a last resort...
Old Dec 9, 2008 | 04:19 PM
Beerstalker's Avatar
Beerstalker
This is great if it works. I recently added a bunch of sound deadening material to my truck and now the pedal won't go down as far as it used to. I have to really stomp on it to compress the sound deadening and get it to go far enough to shift into passing gear. Hopefully doing these steps can recalibrate the pedal to make it so I don't have to press down as far to get full throttle. I'll try it when I leave work tonight and post back on here.
Old Dec 9, 2008 | 08:32 PM
edjunior's Avatar
edjunior
Okay, so how do you know for sure if you have accel-by-wire??
Old Dec 9, 2008 | 09:53 PM
krewat's Avatar
krewat
3-valve engines are fly-by-wire.
Both 5.4 V8 and 6.8 V10 ...
