i fix my pinon yoke and i was drive home in the dark and quess what radio died dash lights and perter much every thing electral died guages lights evan the blinkers what could cause this it happand all at once
did it stay running?if it did did it turnback over after you shut it off?i would check the junction box under the hood to see whats up cause all of it goin out like that has to be a junction bow or fuse box thing i would think maybe check the battery cable running to the box
it ran like a champ but it dint turn over after i turm it off it been dropping battiers for mouth i but a new allternater in it still dropping battiers wheres the junction box
the box with all the fuses under the hood.just follow the big battery cable.the cable could be shot or loose maybe turn your headlights on and wiggle some wires and see if you can find the issue if your headlights turn on.you will probably find your battery killer too
pm me with your email ill send them to ya.when your alternator is working perfect you should have about 14.5 volts coming out of it and batteries should hold about 12.5 i think your main power wire has an issue
my step up is nothing like that half of that stuff in the photo is missing on my truck i like at that same photo dave put up i have to put up a photo of my headach so u can scrach ur head with me to
