Running 8 On 4
Old Dec 9, 2008 | 09:43 AM
Talyn's Avatar
Talyn
Originally Posted by Mark Kovalsky
Sure you can. There is a solenoid that adds clearance in the valve train so the cam can't open the valves.
And you don't need to shut off the coils. Let it fire a spark in a cylinder with no fuel. Nothing bad happens. These systems don't shut off the coils, just the fuel, and deactivate the valves.
Then what is the point if individual coil packs on top of each cylinder head?
Because, you are right, you should just let them fire in there, if there are any gases, or anything, it will just burn them up, but there would never be enough to cause any problems.
Just sounds like its more of a thing to get people to buy vehicles then anything.
I rode in one, you could never tell it switched back and fourth between them, its pretty cool.
But, he said he never noticed any difference in fuel mileage.
Old Dec 9, 2008 | 10:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The point of individual coils is to delete the distributor and the high voltage wires. They cause a lot of maintenance problems.
Look at the Ford modular engines. They have had coil on plug for 16 years and never had cylinder deactivation. Obviously the COP isn't there to be able to disable cylinders.
He never noticed any fuel economy improvement compared to what? How would he know what it would do without the deactivation?
Old Dec 9, 2008 | 10:23 AM
Talyn's Avatar
Talyn
Oh, gotcha. no more wire and stuff, just computer controlled ignition.
Even though that makes it way more expensive.
*shrugs*
Seems like there would still be quite a bit of wire mess to run all of that anyways.
Anytime I've seen them disassembled on TV, it didn't look to fun.
Old Dec 9, 2008 | 11:03 AM
FARM69's Avatar
FARM69
This technology is decades old. I present to you the 1976 IH 1568 V8 tractor that cut down the 4 cylinder when not under load. The engine was rated for 150 HP. Check it out, pretty cool unit and it sounded amazing.
Not sure how it was accomplished but there were doing this 30 years ago on common rail systems.
Old Dec 9, 2008 | 11:13 AM
Talyn's Avatar
Talyn
Yea, and all them V8 tractors were not the greatest though.
If you find a farmer with them, its a conversational piece.
Guy here by me has one in midland.
it just sits there.
From what I've heard and my experience anyways.
It was actually a car motor they put on them and made it work for a tractor from what I was told. That's why it didn't do so good.
Old Dec 9, 2008 | 11:28 AM
FARM69's Avatar
FARM69
it just sits there.
Those old 68's were underpowered and I believe the 75's and 76's were the only ones that have the variable cylinders I believe.
They were definitely not the best choice back then, but the technology was interesting.
Old Dec 9, 2008 | 11:54 AM
Talyn's Avatar
Talyn
Yea. they decided to go cheep. Funny stuff.
They are such huge tractors too!!!
With a bitty tidy engine.
Should put some huge engine to replace it in there, might work better.
Old Dec 10, 2008 | 12:44 AM
FARM69's Avatar
FARM69
I think a lot of guys ended up putting a cummins conversion in them. I think they were just a little ahead of their time. Kind of funny, looking back I can say that about a lot things.
Old Dec 11, 2008 | 10:06 PM
believer45's Avatar
believer45
Fried valve cover gasket and under valve cover harness took out the right bank of my 95 several years ago while I was in Chicago on business. The truck would not get over 30 or so MPH and took a while to get there. When you just shut off power to the injectors you have a 3.65 liter diesel driving a 3.65 liter air compressor and trying to drive your truck.
Dave / Believer45
seankim
Mar 18, 2010 08:47 PM
ABO
Dec 8, 2008 11:34 AM
Faren
Dec 14, 2006 03:37 AM
Monsta
Modular V10 (6.8l)
28
Apr 6, 2006 07:13 PM
DUKFVR
Offroad & 4x4
24
May 23, 2005 09:58 PM
