Sponsored by: Real Truck
Wiring Diagram
Old Mar 18, 2010 | 01:31 PM
seankim's Avatar
seankim
Wiring Diagram
I have a 1999 F350 Super Duty 7.3 Diesel with a service body. My question is. There are four wires which are blunt cut on the drivers side engine compartment on the firewall next to the brake master cylinder. The wires are bundled with the wireing harness coming out of the cab. The wires had a tag which said something like up fitters wiring? The tag fell off. So I would like to know what the wires are for? I would like to wire some switches in the cab for rear work lights and lights in the service body.So if these wires go in to the cab it would be a help. Also does any one know if there are any unused relays in the fuse box? I use the truck for Horseshoeing and would like to wire my fresh water pump also. Thanks for the help.
Old Mar 18, 2010 | 02:10 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe they are called "PASS-THRU" wires. Look inside behind the headlight switch and you''ll find the matching wires.
Old Mar 18, 2010 | 02:11 PM
cworley250sd's Avatar
cworley250sd
Those are "pass-trough" wires, they are blunt cut on either side of the firewall, it is for accessories. Kinda nice of Ford to already have us some wires passed through the firewall. Use them for whatever you like. The other side is under the dash, just remove the knee bolster and use a flashlight and look up you will see them.
Old Mar 18, 2010 | 02:54 PM
12ozd's Avatar
12ozd
Upfitter switches are a nice mod.
Take a look here, from the tech folder.
Old Mar 18, 2010 | 08:47 PM
seankim's Avatar
seankim
Thanks everyone.
Sean
Subzero68
Jun 4, 2014 08:37 PM
kornfanjoe
Oct 15, 2013 10:01 PM
frogracer
2009 - 2014 F150
Jul 3, 2009 05:08 PM
Chuck14
Electrical Systems/Wiring
Feb 23, 2009 04:41 PM
