Rausch Creek?
Old Dec 7, 2008 | 10:26 PM
JethroF250's Avatar
JethroF250
lol thanks for the info. i will take the necessary stuff. i was thinkin the logging road. how is that? what trails you think whitey would make it through safely?
Old Dec 7, 2008 | 10:28 PM
c00nhunterjoe's Avatar
c00nhunterjoe
this is the frog hole, top pic is before, lower is after. i am uplaoding pics of the log trail now..
Old Dec 7, 2008 | 10:32 PM
JethroF250's Avatar
JethroF250
that looks insane. see i want to get as much info as possible so when i get there i know what to do. how did you get there joe? and how long did it take you on how much fuel? lots of questions i know but i just want to know what i'm gettin into
Old Dec 7, 2008 | 10:33 PM
c00nhunterjoe
here is the log trail, its sideways...lol (edit) i fixed the pic.
Old Dec 7, 2008 | 10:38 PM
c00nhunterjoe
i dont recall the exact way, the website gives you the address and i followed mapquest, i burned alot of fuel, i'd fill up both tanks right before you go into the park to be safe, should be similar to what i burned since the old truck was a 460. i think its about an hour and a half to 2 hour drive from here if i recall correctly.
Old Dec 7, 2008 | 10:39 PM
c00nhunterjoe
more of the logging trail...
JethroF250's Avatar
JethroF250
ok looks like whitey should make it. you think my tires are good enough?
Old Dec 7, 2008 | 10:41 PM
JethroF250's Avatar
JethroF250
dam. i cant fill both tanks my rear leaks. how long is the logging trail?
Old Dec 7, 2008 | 10:43 PM
c00nhunterjoe
probably, the trails are all rated and the map they give you is really good, blue-green-red- black. going easy to hard. i would not do the rock creek in your truck nor would i do teh deep pits and bowls. the hill climbs, log trail and other green trails you should do ok on but i gurantee you will get stuck some with your truck, as long as you have the long straps you should be fine.
the jeep is doing a vertical rock wall climb and the high boy is entering the 5 ft mudpit located just inside the park on the "pole trail"
Old Dec 7, 2008 | 10:47 PM
JethroF250's Avatar
JethroF250
how stuck would you say stuck would be? i got a 4000 lbs come along and im takin bout 20 to 30 foot of chain
c00nhunterjoe
then definatly carry a 5 gallon can... the log trails are most of the park.... it was access roads for the log sites... hence the name log trails, they are full of mud spots, stream crossings and deep ruts. here are the maps of the park, 90% of the green trails are log trails...ps, crawlers ridge was crazy!! i had a blast on that one. i dont think your truck would make it. imagine superman throwing boulders into a 200 foot tall mountain of jagged rocks.... thats what you drive up at a 45* angle or greater. you go rock to rock.. i cant find any pictures of that right now though.
http://rauschcreekoffroadpark.org/maps/east.jpg
http://rauschcreekoffroadpark.org/maps/westlg.jpg
Old Dec 7, 2008 | 10:48 PM
c00nhunterjoe
stuck as in you aint moving without another truck stuck.
this is crawlers ridge.- http://www.rc4x4.org/rcforum/index.p...sa=view;id=932
Old Dec 7, 2008 | 10:51 PM
  #28
c00nhunterjoe
one of the ponds..
Rausch Creek Forums - crossing lake christy
  #29
JethroF250's Avatar
JethroF250
my truck definately aint makin that. the only other truck were gonna have is a bronco. he has great tires on it. i hope he can pull me
Old Dec 7, 2008 | 10:52 PM
  #30
JethroF250's Avatar
JethroF250
i'll just stare at the pond from a distance lol
