Which engine would you choose? (kinda long)
First option, there's a guy about 2, 2 and a half hours up the road with a fresh rebuilt 351w bottom end. .30 over with TRW hyper flattops, H beam rods, new oil pump, fresh bearings and rings, and balanced rotating assembly. It's got a pretty big cam, solid roller .600/.600, advertised duration of 286/290, duration at 50 is 254/258. He went 7.4 with this and Pro Comp heads in an old Mustang (translates to a low 12 second motor) then pulled it to freshen it up, then got a good deal on stroker parts so he went that route. So essentially it's a fresh rebuilt hotrod bottom end for $700 that was making 450hp with lower end aluminum heads. Still will needs heads, and would have to have real pricey aftermarket ones to take advantage of that cam and not choke the motor out. Plus push rods, a high stall converter, an intake, plus a big badass carburetor and probably a slew of other small items.
Second option, a local big time Mustang enthusiast has a 460 he pulled from an early 80s extended cab F250. Fairly low miles on a rebuild with .30 over pistons (don't know if they're cast, hypers, dished or flat), a 292 Comp Cam I think he said, Ford Racing lifters, Dove C heads, and Edelbrock intake. He said he would trade straight up for my 351 since he doesn't want to pay $500 for a special bellhousing from Summit that'd allow him to use his t5 on that 460, so he wants to go Windsor and there aren't too many local guys selling running 302/351s unless they're built all to hell. Also, if I threw in the newish clutch/pressure plate from the Fox I just sold (which I got from him), he'd throw in the 460s c6 (mine has a c6 in it now on the 351) but it needs 2 of the transmission ears welded back on, since his buddy was pulling the transmission seperately and broke a couple off. But he said the transmission has low miles and has a 2500 stall converter that he'd throw in. He said I could also keep my current c6, so I could sell it for a few bucks to someone else.
All I'd need it seems is the correct perches from a mid 70s truck that had a 460, so that shouldn't be too hard to source. I'm not sure the horsepower the 460 makes compared to the 351, however I'm not the kinda guy who wants to melt the rubber off the wheels of my truck. I mainly got it because of the look of an old truck, and I want the sound and grunt of a mean v8. I had an LT1 Trans Am all stock, and I LOVED it because it had Flowmasters and loved the sound. It had enough pep for me. So if that car was plenty for me, only making the 275ish hp they make stock, then that shows you I don't need 575hp to be happy.
It seems the 460 might be a better bet since a set of $30 or $40 used perches, and no more labor than pulling the old motor, bolting the perches on, then dropping the bigger motor right in, and then installing a big block c6 in place of my small block c6, would get me back on the road. Plus this guy is only like 45 minutes to an hour away, and would more than likely deliver the 460 while helping me pull the 351. Even if it is stock other than the pistons and cam, I'm sure it makes decent horsepower, but would have near the same torque of the built 351w I was looking at.
Anyone, feel free to chime in with some helpful info or ideas.
See what you have and that way you can judge what you need.
Or clean it off and stay the way it is, and save up for more.
I've gone through the motors believe me. My last 390 was a
top end rebuild and the bottom went out. And the stories on the
other motors are another story.
The W is a transplant, it wasn't available in 66, another W or 302 is a bolt up, swapping in a 460 will require tranny too since they are different engine families.
Can you afford to drive a 10 mpg vehicle?
John
They are important for 2 reasons:
1. They situate the engine and transmission into the correct geometry within the truck.
2. They are cross bolted to prevent ripping the engine into the hood.
One note of caution: Be prepared to pay over a C-note for those perches, though. Most people who have them know what they have, and they often go for well over $100 on E-bay.
Other than that, the rest is easy bolt on parts, or relatively minor machine shop fabrication.
Good luck!
1) you already have the Mounts/trans installed
2) Windosr parts are 1/2 the price of 460 parts.
3) you can squeak 20 mpg out of a Windsor engine. Try that with a 460
