Turbo Help ASAP
Old Dec 7, 2008 | 11:15 AM
c00nhunterjoe's Avatar
c00nhunterjoe
it sounds like yours is operating normal. in cold temps the valve will stay closed as long as you are below (roughly) 1/4 throttle. it is only sticking if it doesnt open when you push the pedal down a little farther than that. if this is the case then the easiest thing to do is just unplug the dam thing. here is a picture of the connector, i tapped the circuit and use the valve as an exhaust brake.
Old Dec 7, 2008 | 11:26 AM
KevinC.'s Avatar
KevinC.
Originally Posted by GWF3507.3
Recent cold snap has caused this to come up temps below 20F.
It's purpose is to help warm the motor on cold mornings, you could always gut it. I don't have to worry about that being in florida, but I know a lot of people who have. So maybe ask one of them what is involved.
Old Dec 7, 2008 | 12:13 PM
c00nhunterjoe
gutting it is not hard, the issue comes with having the pedastool rod dangling there not attached to anything. it WILL leak in time. you can see a 100 degree drop in egt's from the removal of the butterfly in the pipe.
Old Dec 7, 2008 | 04:20 PM
JethroF250's Avatar
JethroF250
he does change the oil but i dont know how often. he hauls cars with it all the time so i suspect he changes it evry 5000. but he could do it every 10 since he drives so much. the truck revs very slow and there is no smoke. yes he still has the cat on the truck along with the muffler
Old Dec 7, 2008 | 09:58 PM
c00nhunterjoe
if he hauls alot then the oil change intervals need to be upped, the more work it does the less you can go between changes(typicly) my guess for now is either a clogged cat (since its a heavy frequent hauler) or sludged injectors(depending on abuse and maintinance)
Old Dec 7, 2008 | 10:15 PM
JethroF250's Avatar
JethroF250
ok i will tell him his opyions. that still dont explain him sayin the turbo "throws" oil
Old Dec 7, 2008 | 10:24 PM
c00nhunterjoe
my guess on that is one of 2 things, the ebp valve at the pedastool leaks or the crank case vent is dumping in the intake
Old Dec 7, 2008 | 10:54 PM
JethroF250's Avatar
JethroF250
ok thanks alot for the info. now back to the Rausch Creek thread lol
Old Dec 7, 2008 | 10:58 PM
c00nhunterjoe
oops, i forgot about the other threads now that you got me on rausch creek! i need some sleep, got to get up at 4 am
Old Dec 7, 2008 | 11:01 PM
JethroF250's Avatar
JethroF250
dang that sucks GO TO BED!!! lol
Old Dec 7, 2008 | 11:03 PM
c00nhunterjoe
yeah, i need to, but the suspense is killing me.
Old Dec 7, 2008 | 11:12 PM
JethroF250's Avatar
JethroF250
do you wanna take a day off and ride with me to Rausch?
Old Dec 7, 2008 | 11:30 PM
  #28
c00nhunterjoe
oh, dont tempt me, if i go i have to take the truck and play! its been almost 3 years now since the last time i went
Old Dec 7, 2008 | 11:37 PM
  #29
JethroF250's Avatar
JethroF250
TAKE OFF WORK!! YOU WONT DO IT TO GO WHEELIN! YOU WONT! lol i'm tempting you on purpose cause you should go
Old Dec 7, 2008 | 11:40 PM
  #30
c00nhunterjoe
if i take off a saturday thats 400 bucks out of the pocket....lol i make 36 bucks an hour on ot. it is very tempting to go play in the mud...... you have me pondering.....hmmmmmm
