oil leak from pipe under manifold?
on
if its about a 3" round pipe...that would be your oil cooler..there is 4 big orings in there..the rebuild kit is about 40 bucks if i remember right..you also need a way to press them back together...i used a 1/2 drill press..Kris (strokin_it7.3) used a wood splitter....
<LEGEND>Attached Images</LEGEND><TABLE cellSpacing=3 cellPadding=0 border=0><TBODY><TR><TD></TD><TD>Oil Cooler O-ring swap.pdf </TD></TR></TBODY></TABLE>
on
call or PM him..he should have kits to do the whole thing.. you need 2 of each oring and a gasket for each end of the cooler... Th!nk Parts Guy
Here is the kit that i used
Your Premiere Source for Ford Truck Parts and Accessories
Just make sure you drain all the coolant and the oil before you take it off... including the block drains...I did NOT do this - dont ask me about the coolant/oil shower i had in 35* temps!!!!
Also, I just used a long clamp to get all the parts pressed back together.
It is pretty simple to do-very straight forward.
Good luck
Good luck
