Sponsored by: Kumho
Lift Question
Old Jan 30, 2002 | 03:00 PM
79bigblue's Avatar
79bigblue
Lift Question
I am thinking about placing two inch spacers between my axel and my leaf springs on my 79 F-250. Is this a good idea or a bad idea?
Thanks
Mike
Old Jan 30, 2002 | 03:26 PM
Ford79's Avatar
Ford79
Lift Question
It will work ok for the rear, but not on the front. The only drawback is that it puts more stress on the springs. A cheap and easy way to lift a truck.
Old Jan 30, 2002 | 05:54 PM
79bigblue's Avatar
79bigblue
Lift Question
What would be be easiest way to achieve around 2 inches of lift reasonably and not using a body lift.
Old Jan 30, 2002 | 08:59 PM
Ford79's Avatar
Ford79
Lift Question
Add a leaf springs. Should be able to get them from any lift mfg. for not much $.
Old Jan 30, 2002 | 11:33 PM
79bigblue's Avatar
79bigblue
Lift Question
These add a leaf springs would be for the front and back sets of springs correct?
Old Jan 31, 2002 | 07:37 AM
Ford79's Avatar
Ford79
Lift Question
Correct. Superlift and Skyjacker have them. Check out their sites for info. You can also check out ntwonline.com Probably have to get longer shocks as well.
Old Jan 31, 2002 | 12:44 PM
79bigblue's Avatar
79bigblue
Lift Question
I found some hellwig add a leaf springs. Are these good or bad.
Old Jan 31, 2002 | 06:49 PM
Ford79's Avatar
Ford79
Lift Question
They look fine to me. Lots cheaper than new spring packs. I don't have any personal experience with them though. I'd personally go with the traditional type that are installed directly into the leaf pack unless you need the adjustable type to make your truck sit level side to side to compensate for worn out body bushings or something. They should come in pairs and have new center bolts included.
Old Feb 6, 2002 | 08:56 PM
fortythree's Avatar
fortythree
Lift Question
the only thing is, if you have fords IFS (independent front end with leaf springs, not coils) and go with an add a leaf, it will be very hard to keep your truck aligned.. i tried to convince my local suspension shop to add a leaf in my front end (i think my front end sits lower than other same year f250's)... i left it with him for the day and went to pick it up and he didnt do it... said it was sitting exactly where it was meant to and that it would thro out my alignment... i was sad.
good luck tho, yours is probably better than mine is! (your luck i mean)
Old Feb 8, 2002 | 12:29 PM
79bigblue's Avatar
79bigblue
Lift Question
So if I have leaf springs in the front an add a leaf is going to throw off my alignment, correct? So what would be the easiset way to lift the front, other than buying a complete kit. Extending the shackles, putting blocks, or will the add a leaf not creat a noticable difference in the alignment. What are some ideas. I all want is to lift it 2 to 3 inches.
Thanks
Mike
Old Feb 8, 2002 | 01:15 PM
Ford79's Avatar
Ford79
Lift Question
You have a solid front axle. The last post is about trucks with the TTB/ leaf spring fronts, 1980-up F250's and F350's. Add-a-leafs should work just fine for your truck. You shouldn't have to worry about the alignment much lifting it only 2-3 inches. Probably a good idea to get an alignment after lifting it though.
Old Feb 9, 2002 | 01:08 PM
destiny88's Avatar
destiny88
Lift Question
ddubbs79
1978 - 1996 Big Bronco
Apr 20, 2014 01:54 PM
Fordman96
Apr 28, 2013 08:09 AM
79OldBone
Oct 4, 2011 12:24 PM
3cornersranch
Nov 18, 2010 03:29 PM
brown79
Alternative Fuels, Hybrids & Mileage
Jan 1, 2005 10:14 AM
