e brake adjustment
Old Dec 5, 2008 | 11:25 AM
Jugger's Avatar
Jugger
e brake adjustment
anyone have a link to adjust the e brake on a 97. mine is way out and i don't have service manual. tia
Old Dec 5, 2008 | 03:12 PM
alloro's Avatar
alloro
Just jack up the back end and spin the wheel as you're turning the adjuster. As soon as you hear some rubbing stop, it's done. Do the same thing to the other side.
Old Dec 5, 2008 | 06:49 PM
Jugger's Avatar
Jugger
where's the adjuster located? is it near the caliper?
Old Dec 5, 2008 | 07:42 PM
Freak4Ford's Avatar
Freak4Ford
Its on the back plate. There is a rubber plug that keeps debris out of it. Remove it and have at it.
Old Dec 5, 2008 | 07:51 PM
alloro's Avatar
alloro
There is a slotted hole in the brake backplate. You have to reach into that hole with a screwdriver or a brake spoon and turn the star wheel inside. Sometimes there is a rubber plug in the slotted hole that you'll have to pull/pry out.
Old Dec 5, 2008 | 09:32 PM
98expeditionXLT's Avatar
98expeditionXLT
When you are done adjusting the e-brake always test drive it and observe that you don't have excessive drag or heat build-up, because you will ruin your e-brake shoes very fast. You also want to check that the e-brake holds by testing it on a hill or with the vehicle in drive, it should hold if you give a little gas.
When I was in high school and college I worked at a garage and the owner adjusted drum brakes by turning the adjuster until there was enough drag so that the wheel would not turn, then backed the adjuster off until there is only a slight drag. To this day I do it the same way.
When my Exp was under warranty, I took it in to a Ford dealer near my job, not the dealer I purchased the vehicle from, for several minor issues including an e-brake adjustment. The knuckehead who worked on it, adjsuted one side only and as soon as I pulled out of dealer lot and reached about 30 mph I could feel the drag from the e-brake so I turned around and gave the dealer hell.
Old Dec 5, 2008 | 11:02 PM
Jugger's Avatar
Jugger
got it, i was thinking there was a cable adjustment. thanks
wolfrace
Sep 24, 2020 07:27 PM
cappo
Jan 29, 2015 09:55 PM
JHoffman93
Dec 23, 2009 09:19 PM
Flareside50
1997 - 2003 F150
Jan 6, 2008 05:08 PM
hasbeen
Sep 19, 2003 08:54 AM
