Leaking Valve
Old Dec 3, 2008 | 05:12 PM
rwlacks's Avatar
rwlacks
Question Leaking Valve
78 F150 factory a/c !!! The low pressure valve at the compressor is leaking refrigerant around the stem { the one you open or close to fill or check } is there a way of repairing this ?? Or buy the whole hose assembly with new valve in place
Old Dec 3, 2008 | 05:56 PM
86F250BIGBLOCK's Avatar
86F250BIGBLOCK
it is a shrader (sp?) valve, just like a valve stem on a tire. YOu can buy a core tool to remove/tighten it, but if i remember correctly it is larger than a tire valve stem. The core may just be loose, or it could be bad. I would check to see if it is loose, and then if it is not i would replace it. You will however lose all your refrigerant, and I'm sure someone will tell you to take your truck to a shop and have the a/c system emptied first (environmental reasons). This however is up to you, because I do not care what happens in your driveway All of the parts can be purchased at a local Auto Zone, etc. Hope this is the issue you were talkin about! Good Luck
Old Dec 3, 2008 | 06:14 PM
rwlacks's Avatar
rwlacks
Thanks but that is the wrong valve on the 70's there was a valve made on the end of the hose that connects to the compressor . This valve usually had a alum. cap over it . This is the one thats leaking
Old Dec 3, 2008 | 06:23 PM
86F250BIGBLOCK
****, I knew that. I guess I wasn't paying attention to the fact that you have a 78 Sorry man, I hope you get it taken care of. I know nothing of how to repair your old stuff
jeffri116
1997 - 2003 F150
May 9, 2016 10:14 AM
tjustice
Jan 20, 2014 05:31 PM
Rusty_S
Jun 23, 2011 09:31 AM
pipercoal
Modular V8 (4.6L, 5.4L)
Sep 18, 2006 06:31 PM
phoneman91
Apr 21, 2005 01:49 AM
