schrader valve removal tips
Old Jun 20, 2011 | 12:40 PM
Rusty_S's Avatar
Rusty_S
Need some tips for removing a broken valve. The bar used to tighten and loosen the valve broke when I tried tightening the valve to stop a leak. It's a r12 valve in the high pressure hard line at the compressor.
Any help would be appreciated.
Old Jun 22, 2011 | 11:51 PM
screaminford's Avatar
screaminford
i just did one of these today. both the high and low side broke. just load it with pb blaster, and use something like this that comes with a really small one. i cant remember where i got mine but it had a tiny one.
Amazon.com: Irwin Industrial Tools 53700 Spiral Extractor and HSS Drill Bit Pouched Set, 6-Piece: Home Improvement
good luck
Old Jun 23, 2011 | 09:31 AM
Rusty_S's Avatar
Rusty_S
good luck
Thanks, ill try that next. I found a tip online about using a t15 torx bit and biting into the opening. I have some with a hole in the middle for removing Ford ignition switches I was going to try when it clears up.
ExPACamper
28
May 12, 2017 11:31 AM
PaxtonQ
29
Mar 8, 2017 05:43 PM
FordTrucksKickGM
1997 - 2003 F150
15
Dec 14, 2016 03:54 PM
Colorado Horseman
Nov 8, 2016 12:49 AM
pushrod92
Mar 15, 2016 12:31 PM
