rod journal sizes
Old Dec 10, 2003 | 06:18 PM
bob arrington's Avatar
bob arrington
rod journal sizes
does any one know the rod journal size on a 390, and is it the same on a 360. thanks bob
Old Dec 10, 2003 | 07:12 PM
Dealford's Avatar
Dealford
They're all the same.
Old Dec 10, 2003 | 08:16 PM
rusty70f100's Avatar
rusty70f100
Yep, all the FE's and FT's you'll ever see have the same size, 2.4384". Nascar cranks had .080" wider journals, and require Nascar rods, or widened standard rods. It wouldn't make sense to run standard rods on a Nascar crank, though.
Old Dec 11, 2003 | 03:13 PM
bob arrington
many thanks
Old Dec 17, 2003 | 07:21 PM
bob arrington
I have one other question , does it matter if the notches in the rods, where the bearings sit, are oposite each other? I have a 360 with them oposite and a 390 with them mixed . the large camfer is matched, no matter which way they face, on the various rods. thanks bob
Old Dec 17, 2003 | 08:37 PM
baddad457's Avatar
baddad457
The notches should go together, they're like that on every Ford Motor I've ever had. Rod #'s ( 1 thru 8) should be on the same side as the bearing notches. The chamfer will face the outside of the rod journal.
Old Dec 17, 2003 | 08:55 PM
bob arrington
Great , thanks for that answer. I have two engines that Ive inherated and I am trying not to make the same mistakes that were made before , mine included, bob
zombiehunter
Oct 3, 2012 01:09 PM
flat6inline
Flathead V8 & Flathead 6
Aug 5, 2007 12:00 AM
Gary Blair
401, 477, & 534 SD Engines
Oct 28, 2006 02:42 PM
46yblock
Jan 30, 2005 01:47 AM
woodsrider505
Dec 20, 2004 05:58 PM
