just bought the dp
Old Dec 1, 2008 | 11:15 PM
conman3300's Avatar
conman3300
just bought the dp
well yes i jusy bought it codes are
0-stock
1-stock
2-80 econo
3-120
4-140 aggressive
5-140 extreme
6-lope idle
7-drive thru
but the sad part is i have to wait to buy gauges and the bts vb and the reason i bought the chip first is that i have the money for that now and would like to just have it on hand for when i get all the other stuff in which will be about a month((((
do yall think this was the right thing to do or no
Old Dec 1, 2008 | 11:17 PM
Izzy351's Avatar
Izzy351
Did you get the tunes set up for the mod'ed VB? If not, you can put the chip in now, but take it easy on it. Do you have and exhaust & intake yet?
Old Dec 1, 2008 | 11:20 PM
jdecker88's Avatar
jdecker88
You could have saved a few bucks if you just got the 140 Aggressive and ditched teh 140E and the 120Race tunes because they are all the same. Now the bad thing is if you don't have the BTS VB and the tuner is set for it you cannot even use the DP because the tranny shifts will be very rough. Also most people set the 0 postion as a no-start instead of two stocks.
Old Dec 1, 2008 | 11:22 PM
conman3300's Avatar
conman3300
i really am not sure i got it online and didn't know where to put it but i emailed them right after i ordered it so well have to wait for the answer
and yes i have an afe stage 2 intake four inch exhaust and the tru cool transmission cooler
Old Dec 1, 2008 | 11:24 PM
conman3300's Avatar
conman3300
my bad i did put the o position as no start
and yes i no it was a bad idea but i figure if i don't use it i don't know what i missing but if i use it and then lose it for a bit it will suck ha so right now im stock so its all god until i get it all up and running
Old Dec 1, 2008 | 11:31 PM
Izzy351's Avatar
Izzy351
Did you tell DP you had a modified tranny? If you didn't, you can run the chip tomorrow. With your mods, you'll have to tow heavy up a hill or floor-board the pedal and sustain 100+ mph for minutes before you cause damage.
Old Dec 1, 2008 | 11:41 PM
conman3300's Avatar
conman3300
ya i think i did im not sure yet at all i sent an email to them a little while ago and will have to wait and see if they change it for the vb
but if they don't i will install it right away ha kinda hoping they don't now because iv been reading the stories and i want my own
so basically what are some bad temps to be getting once i get the gauges
thanks
Old Dec 1, 2008 | 11:48 PM
liftedgrocerygetter's Avatar
liftedgrocerygetter
Your tranny should be around 60-100* above outside temps and you don't want your EGT's to climb over 1250* for longer than a min or so.
Old Dec 1, 2008 | 11:52 PM
conman3300's Avatar
conman3300
ok cool thanks and also is it hard to drive now with the power yall are getting with the chip like taking corners and things
thanks
Old Dec 2, 2008 | 12:52 AM
liftedgrocerygetter
I only have the 80E but I have no problems with the power or corners. The only problem I have is my fuel gauge drops to quickly from stepping on the go petal to hard to see the smoke come out the pipe and putting little cars and other trucks in thier place.......
Welcome to the perma grin club!!
Old Dec 2, 2008 | 06:15 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Give Jody a call. He will talk to you and recommend what you need. If you are going to get a VB in a month, I would have him go ahead and set the chip for it, if not you will have to send it back to have the tunes reburned. That is if you are getting the F-5. If you are getting the F-6, you may be able to download the revised tunes. I wouldn't get the 2 140 tunes, I would stick with one.
You need to call him before he burns it. Good luck. You will love the new power. Get them gauges in asap.
Old Dec 2, 2008 | 07:56 AM
MapleShadeDiesel's Avatar
MapleShadeDiesel
As a new member of the permagrin club I would say put it in and worry about the other things later. Bigger exhaust and intake will keep you safe. Don't hold the peddle down too long in the 140 setting without knowing the egt. Other then that start it, warm it, and beat the hell out of it. Welcome to the club, you will love it.
