Sponsored by: Real Truck
Heat Shield/Pad
Old Dec 1, 2008 | 08:04 PM
jjcomputer's Avatar
jjcomputer
Heat Shield/Pad
There is a padded heat shield that appears to be glued to the underside of the bed that I assume protects the bed from exhaust heat (and in my case my LineX sprayed liner too!). Mine is falling down onto the exhaust, any suggestions on a type of adhesive for this application?
Old Dec 1, 2008 | 08:42 PM
ReAX's Avatar
ReAX
If you can clean it well, 3M super 77 will do the trick. It's available in a spray can. If you can't clean the area, then you might try caulk or RTV.
norts1138
Aug 28, 2014 12:21 PM
Diesel cat
Dec 4, 2011 10:05 PM
ford66
Aug 17, 2009 08:09 PM
Green Streak
Dec 1, 2005 03:58 PM
