what should the normal compression pressure be for a 74 truck 390? ford manual says "lowest reading must be within 75% of highest, to be within specifications." but lists no readings. i have 135 to 105. engine runs very sluggishly. what test should i run next to help determine problem? thanks.
Well I dont know off hand...but a 25% difference seems to be to wide of a spread to me...I have always went within 10% in all the cylinders.. But with that said 105 to 135lbs seems to me a bit low.. JMO
My '74 360 had about that much compression. But that is a big range between 105 and 135.
I'd do the "wet vs. dry" test also - and see if the compression comes way up when you drop some oil in each cylinder. That'll tell you whether it's rings or valves.
Did you check the timing? What is it at? Also, is the mechanical (and vacuum) advance working? Take off the distributor cap, and rotate the rotor COUNTERclockwise and let it go. It should move somewhat and then come back easily and not have to be manually rotated back. That means the mechanical advance is working. Then, disconnect the vacuum hose to the vacuum advance can on the distributor, and suck on it with a hand vacuum pump or if the hose is clean, your lips
Make sure the distributor plate is moving and then comes back when you let the vacuum off.
I've always gone with the "withing 10%" as well. Sorry I don't know what stock compression should be either, but 135 sounds to be on the lower acceptable side to me...much less 105. Sounds like a rebuild may be in your future.
Cant never say whats an exceptable PSI is for an engine. All depends on a camshaft used (Hyd, Solid, Roller, Lift & Duration) and C/R. I have seen race engines @ 125 psi or so. My 428 ran 220psi. Some bled off more then others. The biggest concern is the 10% rule. From highest to lowest. Other then that it doesn't really matter.
I recently tested the 360 listed in my signature and the readings range from 130 to 145 and it runs great.
