Sponsored by: Kumho
Brake Problem!
Old Oct 17, 2006 | 01:39 AM
fitmonkey1219's Avatar
fitmonkey1219
Brake Problem!
recently my brakes have been acting up...I will get on my brakes to stop and the pedal won't move (feels like there will be something behind it preventing it from moving)...I then get off the pedal and try again, and finally it moves and i come to a stop. This tends to happen alot, and it's kinda dangerous...why is it doing this??? Help please!
Old Oct 17, 2006 | 05:06 AM
tewferford's Avatar
tewferford
Sounds like your power brake booster. Check vacuum line going to it. It may have a crack,or the grommet it plugs into. Also listen for vacuum leak around booster itself.
Old Oct 17, 2006 | 08:28 AM
rboeding's Avatar
rboeding
I don't know what year you have but the piviot point on the brake pedal can bind up in side the cab. If you pull out the bolt and clean it and put a little white grease on it it can help alot.
Old Oct 17, 2006 | 11:22 AM
fitmonkey1219
sorry for that...its a 2000 f 150...took it out driving this morning and it still did it a few times. I never know when it will do it. Just tends to have a mind of it's own.
Old Oct 18, 2006 | 05:04 AM
tewferford's Avatar
tewferford
Does your brake or ABS light come on when this happens?
Old Oct 18, 2006 | 11:30 AM
fitmonkey1219
i actually removed the ABS due to a lift I put on the truck, although this problem has been recent and I've had the lift on for a while...
rexpedition99
Jun 28, 2025 08:14 AM
rhoward
Jan 10, 2025 05:06 PM
kyle j
Apr 23, 2016 05:44 AM
calbery
Nov 13, 2015 03:49 PM
CommercialNuke
Feb 1, 2009 02:07 PM
