Radius bushings
Old Nov 30, 2008 | 01:56 PM
sandmaniac's Avatar
sandmaniac
Radius bushings
Great to be back home, and thanks in advance for all the great information from many great minds here. I have a 94 Limited 4x4 explorer that needs bushings repalced. I would like to tackle it myself and am very capable. Just wondering if anyone can give me a link to a good manual, or any advice. Any help would be greatfully appreciated.
Old Dec 6, 2008 | 05:07 PM
aquanaut20's Avatar
aquanaut20
Have been meaning to get back to you but got real busy.
2 main ways of doing this job:
  1. remove the nuts and washers off the radius arms, connect an axle strap to the front axles and to a come along, pull the whole front steering/diff assembly forward until the R/A are free of the cross member, replace the worn bushing and reverse the pull.
  2. grind the heads off the rivets securing the cross member to the frame rails, punch out the rivets. Remove the R/A nuts and bushing, pull back the cross member and re/re the front half of the R/A bushing. Re-install cross member using grade 8 bolts/nylock nuts.
FWIW: I used the second method, done in 45min.
Hope this helps
ramick
21
Oct 6, 2013 08:20 PM
ronjon95
May 19, 2013 09:48 AM
custom1106
Jun 29, 2012 11:03 AM
longhorns13
Jan 25, 2011 02:48 PM
Mr Mopar
Bronco II
Sep 14, 2004 08:31 PM
