I just got finished replacing all the busings on my '85 F150 4x4. Everything went great, some were pretty nasty and original and were a pain to press out.
The radius arm bushings went great. I actually replaced them about 2 years ago with regular rubber bushings but still had play in the steering. I recently noticed the drivers side radius arm nut would bottom out before the bushing was tight allowing the arm to still move.
When replacing all the chassis bushings recently I used all poly stuff. I changed the radius bushings out to poly as well....but I still have the same issue!
What's the deal? Even with the poly bushings the arm is still loose and pops while driving. I double checked the part #'s and they are correct.
