Power Steering Leak
Old Nov 30, 2008 | 12:58 PM
BAJI26's Avatar
BAJI26
Power Steering Leak
I have a small leak around the power steering, dunno if it coming from around where it mounts to the engine or its coming from the pulley bit it has gotten alittle worst over the past couple of days, before it was just alittle damp.
Old Nov 30, 2008 | 03:52 PM
kappysworld's Avatar
kappysworld
I have seen it aroung the fittings. of the pully shaft.... You can try adding the stop leak stuff... A replacement is under 200.00
Old Nov 30, 2008 | 07:23 PM
BAJI26's Avatar
BAJI26
Thanks! Is it the steering fluid stop leak? Should I drain the existing fluid and add the power steering with stop leak since I've never changed it before?
Old Nov 30, 2008 | 07:58 PM
ReAX's Avatar
ReAX
That stuff is mostly gimmick. If it's the seal on the shaft, you probably have a bad bearing or some other reason the shaft isn't turning true. You can try it, but it's a band-aid not a cure. Check your lines, make sure they are tight and the leak isn't coming from them or the fittings. If it is the shaft seal, plan to replace it.
jimmmack
Jan 20, 2025 08:29 AM
mjtpolice76
Jan 15, 2013 08:43 PM
spdracer71
Apr 4, 2012 01:15 PM
Zwalters
Feb 14, 2012 08:18 PM
jpjahn
Jul 25, 2005 11:15 AM
