I'd like to lower the rear of my truck about 2 inches in order to level it out.
I've heard of the shackles, but have been unable to find any for a 73.
Any help?
Thanks,
Don
:-X11
1973 F250 3/4 ton Custom
390 .060 over w/428 inside (422?)
Edelbrock Performer intake
Holley 4160 carb
14" K&N Filter
True Dual Exhaust
and more to come.
:-X11
I have had a bunch of trouble with AIM stuff over the years, although they do sell what you are after. I would recommend DJM suspensions. Check them out at DJMsuspensions.com. They also sell what you are after, and i have had good luck with their products. FOMOGO
AZ4x4f150 - Where would those factory lift blocks be located?
FOMOGO - I'll give DJM a try if the factory lift block thing doesn't pan out.
Don
Holley 4160 carb
14" K&N Filter
True Dual Exhaust
and more to come.
The lift blocks would be located under the leaf spring pack on top of the spring perch which is welded to the axle to hold your axle to the truck ford put lift blocks in their 4x4 and 2 wheel drive trucks for load situations when you load the truck the truck should (key word should ) look level all you would need to do to lower the rearend is take the blocks out and retighten the u-bolts to the axle.
