Front-end Noise
Old Nov 29, 2008 | 11:39 AM
twags6's Avatar
twags6
Originally Posted by Lovin7.3
all pepboys had was one for a 4wheel ABS truck. Mines only 2 wheel ABS. I think I could prolly cut the ABS wire off of it and use that one. Am I right?
The abs assembly has the hole for the sensor and tone wheel. You could just leave it in there and tie the wires off to the side.
Old Nov 29, 2008 | 11:43 AM
Lovin7.3's Avatar
Lovin7.3
Thank ya. Thats what I was thinking.
Old Nov 29, 2008 | 11:57 AM
triskit16's Avatar
triskit16
Early Bird 99
While we find your parts, please enter your ZIP Code at PartsAmerica.com 489.99
Later 99
While we find your parts, please enter your ZIP Code at PartsAmerica.com 215.99
Old Nov 29, 2008 | 11:59 AM
Orezona's Avatar
Orezona
Here is Powerstrokeshop
Item Number Price
515020KIT $312.47
Front Hub Brg Assy Kit 4x4 F250-350 built 1999 to 2004
When you purchase a hub bearing from PowerStrokeShop.com
we give you everything you need to get the job done in one convenient package!
Our Hub Bearing assemblies come with the following:
1-Ford Hub Seal Part-no. F81Z3254CB
4-Studs to connect the hub bearing to the knuckle F81Z1107AA
4-Nuts for the above studs F81Z1120AA
1-Ford Yellow Hub to Knuckle O-ring F81Z4A322AA
1-Front Axle Sealed Bearing and Hub Assembly fits 4x4 F250-350 built after 3/22/99 with SRW 4 Wheel ABS. Also fits 00-05 Excursions.
Old Nov 29, 2008 | 03:39 PM
Lovin7.3's Avatar
Lovin7.3
Thanks Jason. Ill be down there Monday to pick that up due to the 90$ shipping charge.
Old Nov 29, 2008 | 03:53 PM
Orezona's Avatar
Orezona
When you think you will be there? I work just a few minutes away.
*Their shipping is out of control. But if you live close it is hard to beat the prices.
Old Nov 29, 2008 | 03:59 PM
Lovin7.3's Avatar
Lovin7.3
Well a buddy of mine with a 6.0 works on the north-east side of Indy and he is going to stop by after work and pick them up for me. He has to get ball joints and they wanted $90 to ship everything to Lafayette. So its like an hour out of his way but and hour is worth $90
Old Dec 3, 2008 | 03:26 PM
Lovin7.3's Avatar
Lovin7.3
Well i got all the parts. Going to go change it right now. Thanks again Jason!
BullsOnParade88
1997 - 2003 F150
Dec 2, 2014 03:58 PM
ford303
2004 - 2008 F150
Apr 29, 2013 09:49 PM
hott-rodd
Dec 19, 2009 11:40 AM
bassaway
1983 - 2012 Ranger & B-Series
Jun 30, 2005 10:51 AM
