trans pan question, shalow or deep
I have the MAG HTYEC deep pan
it holds about 8 extra qaurts of ATF
I have heard differing view points on a stock vs deep tranny pan
as far as extra cooling and other attributes. Some say they are a positive modification/upgrade vs some saying stock capacity is fine.
The def improvement is most aftermarket pans have incorporated cooling fins built into them and a magnetic drain plug and a port for a tranny temp sender.
the addition of a bigger cooler is a def improvement.
Also a shift kit, like TransGo Tugger or a upgraded VB def strengthen the 4R100 auto trans
