Dead spot
Old Nov 28, 2008 | 10:55 AM
broncobilly66's Avatar
broncobilly66
Dead spot
06 screw fx4 all stock other than 2" AS... Sometimes when i slow down to turn or for traffic, when i go to accelerate the truck will downshift like it should and the motor will fall on its face for a second or so.. its like an old carb. motor with a dead spot. really irritating .. I thought it was b/c i was running E85 but now i've run a few tanks of gas through it and it still does it sometimes.. Is this a dealer issue , if so i need to get it done my warr. runs out in feb. Or is this part of the drive by wire lag... would a programmer fix it? TIA Billy
Old Nov 28, 2008 | 06:24 PM
rplatt56's Avatar
rplatt56
The hesitation you are describing is normal in the newer F150s. The only fix for this is to get a tuner for it.
Old Dec 1, 2008 | 03:37 PM
Shmuck's Avatar
Shmuck
yes a tuner definatley helps, but if you dont want to go that route, i heard that there is a trick to solve this.
1) turn key ON (not to start)
2) push throttle pedal to the floor and hold
3) turn key off
That should help.
I tried this and it worked, but i have since installed an Edge Evo and hesitation is a thing of the past.
Hope it helps
Old Dec 1, 2008 | 08:24 PM
enggass's Avatar
enggass
What? First I've read of this... Anyone else? What exactly does that achieve/do? How long do you hold it?
Old Dec 1, 2008 | 09:27 PM
boomer08's Avatar
boomer08
I have read about this before and tried it and it did help. As with Shmuck I too have done the tuner route which took care of the problem.
Old Dec 1, 2008 | 11:05 PM
kd4crs's Avatar
kd4crs
There is a TSB to address this concern. I had the same problem and had the dealership do the reflash per the TSB and it helped a great deal. The problem did not completely disappear but it is nearly unnoticeable unless you know what you are looking for.
Old Dec 2, 2008 | 12:15 AM
Shmuck's Avatar
Shmuck
kd4crs is right, dead spot is dimished, but still lingering there in the background. But it will be better then what you're experiencing now. A reflash might help as well. Theoretically the dealer should do this conjunction with your service visits.
To clarify.....
2) push throttle pedal to the floor and hold (hold for a few seconds)
3) turn key off
4) process complete
IF that doesnt work, try this
1) push pedal to the floor, hold
2) turn key to ON (not to start)
3) wait 5 seconds
4) turn key off
process complete, start, go driving.
For some reason, since re-reading my post i think the correct procedure is the second one listed, but i cant remeber where i discovered this little trick to confirm.
Anyhow, one of the the methods will work. I hope you find it helpful.
Cheers
Old Dec 2, 2008 | 06:07 AM
jakdad's Avatar
jakdad
Hope it helps
Where is the best place (price) to buy an edge tuner?
Thanks,
Jim
Old Dec 2, 2008 | 04:02 PM
F150BOB1's Avatar
F150BOB1
Bronco Billy66 , Go To The Dealer And Have The Transmission Reflashed/software Upgraded. I Had It Done 2 Months Ago And Now Is Shifting Fine. Had The Same Problem You Are Talking About.
There Is A Tsb For This. It Will Be Free Of Charge For Them To Do This. Under The 3/36 Bumper To Bumper Warranty.
Old Dec 2, 2008 | 08:03 PM
broncobilly66
Thanks for all the replies ..I'm gonna give the dealer a try first, I need to take advantage of the warranty while it lasts. I'm off friday i'll try to get it done then... I'll report back
tex25025
Tennessee Chapter
Jun 23, 2010 10:04 AM
billy46
1947 and Older Ford Trucks
Jun 5, 2008 08:20 PM
billyn
May 15, 2008 08:21 AM
billy3p
25
Sep 26, 2007 11:39 AM
Billy Bronco
1978 - 1996 Big Bronco
May 23, 2003 12:49 AM
